1993 skidoo - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 22 (permalink) Old 11-14-2006, 08:26 PM Thread Starter
kzrider40's Avatar
1993 skidoo
hi all, i am kinda new to the forum. i was a member a while back when i put a rotax 340 on a gokart and needed some help. you all help to the max. now, i just bought a 1993 ski-doo formula plus x rave 600cc. it was sittin for a while and i just got it started after like 1/2 hour of trying. anyone on here know anything on these sleds? i was told that it was a race sled from ski-doo but that was back in its time. it only has 2000 miles on it which i thought was low, but i don't know. can anyone fill me in on these sleds that know's about them. thanks.
kzrider40 is offline
post #2 of 22 (permalink) Old 11-14-2006, 08:50 PM
Mountain M0DERAT0R
PolarisINDY500's Avatar
cant really help you out that much, but id like to see some pics of the sled.
2010 Arctic Cat M8 SP 162 (Jan '10 SOTM; '09-'10 SOTY)
MBRP Can, Polished Pipe, Powder Coated Tunnel & Bulkhead, M.A. Track Rack, XXXModRods Vents, AMP Gage Cage, Ice Scratchers, IceAge Rails, Shift Assist, Glide Washers, Rock Rollers, Frogzskin, BDX Anti-Slop & Anti-Stab, Air Can 2's, 44/36p helix, White SLP Powder Pros
The Original Logo ->
Originally Posted by Ultrafrozen View Post
This guy has been on this forum so long there is moss growing on his username!!!
PolarisINDY500 is offline
post #3 of 22 (permalink) Old 11-14-2006, 09:11 PM
The "X" had 40mm carbs, a different rotary valve setup, different front suspension components, different gearing, etc. The engine is a 617 and they STOMPED back in the day....
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #4 of 22 (permalink) Old 11-14-2006, 11:36 PM
These were factory race sleds, very fast. The front suspension is a couple of inches wider then the regular sleds. As mentioned the Engine was also different in that it was wide for the day I guess. It probably has a "upgraded" rear shock and a better seat then the regular plus. I believe it is a little more valuable then most pluses, I personally have interest in them due to liking the regular pluses so much. Do yourself a favour and check the rivets which hold the heat exchangers to the tunnel. On mine they became worn, pulled through and lead to the tunnel actually cracking around the rear of the tank area. All you have to do is replace any that are loose. The heat exchangers are a key support member for these sleds. One other tip, keep out of the trees !!! the hood as you know has no bumper and due to them getting damaged alot those hoods are a mint to replace.
My thoughts.
BrianC is offline
post #5 of 22 (permalink) Old 11-15-2006, 07:30 PM Thread Starter
kzrider40's Avatar
hi,
well, i started the sled up today and had it running just a bit. sounds like it has mad power but that will tell when put to the test. i checked the rivets and all are good. i'm still in the prosses of putting this sled back to normal. the story go's, the original owner( norm )of this sled road with his brother-in-low and his brother-in-low did an oopp's with his sled and died, so after that happen norm parked the sled and never road again. sled sat in a shed for years. i was into karts and had a 340 rotex on a kart. one of my friends decided to build a kart with a snowmobile engine too and bought this sled off of norm and took it apart to use all the engine parts and what ever he needed. but at the time i had sold my kart and my friend lost intrest on building a kart. so it sat for two more years. then i was going to put the sled on ebay for my friend but i decided to keep it for me. i put the sled all back together and thats were i am now. but this sled is all their and in good condition. and the track was new at the tim of it sittin. so now i wanna have fun with this thing but i need to make sure its all put together right before i do any riding.so, dose anyone know were i can download like a shop manual?that would really help.thanks. i hope i didn't bore anyone with the sled story.
post #6 of 22 (permalink) Old 11-15-2006, 09:12 PM
Don't know of anywhere to download it, I see them on ebay quit alot. A Chilton's should run you 40 bucks and aren't too bad. The Skidoo manuals are more like 100+. If you do find one online let me know.
One other thing that I forgot to mention was that you should get your clutches checked out by someone who know's what they are doing. I never had mine done and now there is a lot of wear damage that cannot be inexpesnively fixed. Better to pay some now then a WHOLE LOT later.
BrianC is offline
post #7 of 22 (permalink) Old 11-16-2006, 06:14 AM
CLymer makes a "formula series" manual, like $20. That's the one I have, very informative. Do a eBay search on Ski Doo Clymer.
1999 Ski Doo MXZ600
post #8 of 22 (permalink) Old 11-16-2006, 05:35 PM Thread Starter
kzrider40's Avatar
yea, i'll have to buy one i guess. thanks guys.
post #9 of 22 (permalink) Old 11-17-2006, 05:06 PM Thread Starter
kzrider40's Avatar
well, i just put the sled all together and all i have is three words.O MY GOD. ok, two words and one letter. i was having problems starting the sled and the plugs getting wet, so i took the carbs off and cleaned them really good which their were cloged with old gas, and the first pull. bam started right up. crazy but took it out in the field, and punched her and my god. the front came off like three feet. had to go change my undies. then hit it again and this time i played with the throttle to keep the front off the ground for a good distance. man. all i can say is for a 1993 this thing has mad torqe and lots of it. i'm just so glad that i fixed the problem. now she starts the first pull. thanks all.
post #10 of 22 (permalink) Old 11-17-2006, 08:04 PM
snoeproe's Avatar
the '93 Plus X was a 580 RAVE.
very fast sled!
'71 Arctic Cat Panther 399
(2) '77 Yamaha srx 440's
'75 Yamaha GPX 433
'77 Arctic Cat Kitty Cat
'81 skidoo 9500 Blizzard
'82 skidoo 9500 Blizzard
'83 skidoo 9700 Blizzard
'99 skidoo MXZ 600
'06 skidoo GTX 500SS
snoeproe is offline
post #11 of 22 (permalink) Old 11-17-2006, 08:47 PM Thread Starter
kzrider40's Avatar
fast indede
post #12 of 22 (permalink) Old 11-18-2006, 08:47 AM Thread Starter
kzrider40's Avatar
dose anyone know of some clubs in my neck of the woods? i live in the lancaster pa area? thanks.
post #13 of 22 (permalink) Old 11-18-2006, 11:44 AM
allisonmo2's Avatar
i am in lancaster too(conestoga) a couple of buddies of mine have cabins up in potter cty about 3.5 hrs north. we will be riding all winter long and are planning a few trips to ny and possibly ontario after we get passports. i personally don't know of any clubs around here. check out i think m&s. they are a big arctic cat dealer up on 322 right off 222 outside of ephrata. they will know where and when to ride around this area.
mike
allisonmo2 is offline
post #14 of 22 (permalink) Old 11-18-2006, 01:02 PM
BTW, I was looking at the picture and I had to look twice, your garage looks almost identical to mine with the shelves and everything
1996 Formula SS 670
1989 Polaris Indy 340
1981 John Deere Trailfire 440
1994 Nissan 4x4- Primary Tow Vehicle
If you find yourself in the Magic Kingdom in the next few months, LOOK ME UP. I work in Cosmic Ray's Starlight Cafe. Ask for Dr. Fun!
Click Here To View Chef Tim's Photo Album
JohnDeereSleds is offline
post #15 of 22 (permalink) Old 11-18-2006, 02:50 PM Thread Starter
kzrider40's Avatar
m&s
mike
thanks, M&S is like a block away from me. i was just their to take a friends bike over and was looking at their snowmobiles. cool place. yea i live really close to them. i'll have to give them a call. thanks man.
post #16 of 22 (permalink) Old 11-18-2006, 02:55 PM Thread Starter
kzrider40's Avatar
here she is done.
SHE'S NOT AS NEW AS THE ONE'S I'VE SEEN BUT SHE'S A GO GETTER.
post #17 of 22 (permalink) Old 11-18-2006, 07:00 PM
A god among men
BRPforlife's Avatar
Looks fast just sitting there!
Very clean sled, you should be proud!
BRPforlife is offline
post #18 of 22 (permalink) Old 11-18-2006, 07:13 PM Thread Starter
kzrider40's Avatar
fast
thanks bro,
it is very fast. i really don't know too much about sleds but i do know when something has lost of torq. i should have had my boy take a pic of me doing a wheelie on this thing. i was talking with the original owner of the sled and he told me that when he use to ride with his friend that they would take him on the turns and stuff but when it came to full out throttle they had no chance. i'm not out to race but thats nice to know. this is my summer toy.
ITS A 1978 KAWASAKI KZ1000 TOTALY RESTORED BY ME. TALK ABOUT GETTIN UP AND GOING, THIS IS IT. THIS IS OLD SCHOOL ALL THE WAY.
AND THIS IS WHAT IT USE TO LOOK LIKE.CAN YOU ALL TELL THE DIFFREANCE?
post #19 of 22 (permalink) Old 11-18-2006, 09:38 PM
I just fix 'em...
IRONDOG's Avatar
[/QUOTE]
Nice bike, but it's not restored, it's modified. If it was restored it would have 4 individual chrome exhausts and some other things that are missing.Jerry
IRONDOG is offline
post #20 of 22 (permalink) Old 11-18-2006, 11:46 PM Thread Starter
kzrider40's Avatar
your right jerry. i am so sorry for that. but. if you had seen this bike when i first got it you would say it was restored now. yes, modified AND RESTORED. thanks for noticing. juan.ps nothing missing. just replaced.
