Old 09-09-2006, 03:06 PM   #1 (permalink)
jayzed
Loose steering on '00 MXZ 700
I just bought this sled last week, I was looking it over again today and it seems that there is a bit of play in the handle bars. How can I tighten that up?
jayzed is offline   Reply With Quote
Old 09-09-2006, 03:27 PM   #2 (permalink)
shawnyD
vroom vroom
shawnyD's Avatar
check and replace all rubber bushings in the steering thing. check everything for worn out pieces
LOUD PIPES LOSE TRAILS!
shawnyD is offline   Reply With Quote
Old 09-09-2006, 06:48 PM   #3 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
As shawny said replace the bushings in the steering "thing". There's generally a little bit of play in the bars. If it's really bad than replace the bushings, but don't freak out because it may not be as bad as you think. On both my sleds there's a good half inch to an inch of play in the bars.
Old 09-10-2006, 08:38 PM   #4 (permalink)
jayzed
Thanks guys.
I will see how it is when I actually ride it. It probably isn't too bad. I'm sure my Indy was probably worse. Just want to make sure everything is tip-top before the snow falls.
Old 09-11-2006, 10:42 AM   #5 (permalink)
sleddermxz
Check all your tie rod ends also. Too much play may make it dart on a groomed trail. My sled has only 1500 miles and there is about a 1/2 inch of play in the bars.
sleddermxz is offline   Reply With Quote
Old 09-11-2006, 07:27 PM   #6 (permalink)
shawnyD
vroom vroom
shawnyD's Avatar
all sleds dart on the trails will stock skis. play in the steering makes it just more prone to darting
Old 09-12-2006, 01:02 AM   #7 (permalink)
Too much down pressure on the skis will also contribute to the "darting" problem.
