Dear Ski-doo owners,
Newbie needs your help. I was reading the rest of this thread and thought I could find the answers to my questions here. Here's the story and possible problems. I was given a 1985 Grand Safari Luxe LC which as far as I can tell hasn't been started for a good 10 years. It was stored outside but luckily not on the ground so the undercarriage is rusty but doesn't look to bad. Unfortunately, there are a number of other issues; lost key, bent ski, damaged hood, broken windshield and damaged seat just to name a few. I won't mind spending the money to fix these other problems as long as I know it runs. I would like to see if she "fires" before moving on, which leads me to the basis of my questions. According to the engine plate, this sled is equipped with the Rotax 521cc type 537 engine. From what I read a few posts back the two oil reservoirs that are mounted behind the motor are the oil injection reservoir (large res.) and lubricating oil reservoir (smaller).
My first quesition is: the smaller reservoir has a feed line coming off the bottom but unfortunately is broken off and I can't seem to find where it goes (can't find the other end), where should It be going? What type of oil is used here?
My second question is: Is it possible to by-pass the ignition cylinder to find out if this motor has spark? Unfortunately, there is no key. The ignition has 5 terminals on the back of it, which are labled: Battery (heavy red), Solinoid (heavy red with green stripe), Accessory (double smaller red), Magneto (double smaller blk) and Magneto (double smaller blk with yellow stripes).
Third question: Since I don't know the condition of the injection system, can I pre mix the oil and gas? If so, what would be the ratio?
Likewise, there was mention earlier of
OnlineMicrofiche Index that has microfiche data, unfortunately for me this website only dates back to 1987. Are there any other sites like this that would have information on a 1985.
Thanks for all your help in advance. Steve
