Old 07-07-2006, 03:13 PM   #1 (permalink)
mxnate116
summit 670
are there cheap mods for the summit 670? i was thinking of getting rid of the airbox for two k&n filters with snowchargers and rejetting. is there anything that can be done with the exhauste valves? and i was curious to the benifits of a rotory valve with other then stock timing. would this help and should i have more or less timing? thanks in advance for any help you can give.
mxnate116 is offline   Reply With Quote
Old 07-08-2006, 07:28 PM   #2 (permalink)
The biggest bang for the buck is clutching all the way. You'd be amazed on how tuneable the Rotax clutch is. RAVE's are pretty much fixed like they are. Same with timing, you'll see a minimal improvement comparable to what can happen to the motor with too much timing.
Old 07-08-2006, 07:49 PM   #3 (permalink)
BRPforlife
A god among men
BRPforlife's Avatar
Since it's a summit I'll assume you do a lot of powder riding. Those K&N filters will ice up from melted snow, and a wet filter is never good! I'm with SEG, throw a clutch kit on it! If you want a little more low end grunt than dropping a tooth on the top gear will help. You can use your stock chain but expect to lose a couple mph on the top end.
Old 07-08-2006, 07:57 PM   #4 (permalink)
mxnate116
thanks for the help guys. so for the clutch do i get a new spring or weights or how do i tune it? also is there any gain from a wave/lightweight brake rotor?
Old 07-08-2006, 08:33 PM   #5 (permalink)
The things you suggest are all minimal gains for a LOT of cash...Buy a clutch kit specific to what you want. You can get drag kits, mountain kits, etc. Do a yahoo search for "snowmobile clutch kit".
Old 07-09-2006, 12:46 PM   #6 (permalink)
skidoo kid 102
sundaypuncher 503
skidoo kid 102's Avatar
check out www.mcbperformance.com they have some pretty good stuff for the 670.
THE BEST THINGS IN LIFE GO BRAAAAAP!!!!!!
skidoo kid 102 is offline   Reply With Quote
Old 07-14-2006, 07:33 PM   #7 (permalink)
BskidooC
BskidooC's Avatar
670's are awesome with dual pipes and dual cans
and they have a nice low sound
you might want to consider that
