Hey guys, picked up a 78 Everest 340, starts and runs great but as soon as the throttle is more than halfway it bogs almost to a stop. I made sure the carb is clean, and everything adjusted properly, put in new condensers and points and adjusted everything and checked it twice, new plugs, wires, coils... can't seem to shake the problem, compression test was 90 psi in pto cyl and 120 psi in mag side cyl. Not sure if that's enough to cause this much of an issue.
You are in need of a top end refresh at the very least.
That wide of a spread between the cylinders compression is the issue.
You are getting too much "blow by" in the PTO side as the rpms increase.
You are also likely in need of a new crank seal on that side.
Thanks guys. Ripped the motor apart and found a bad head stud and pistons that need replacing
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
