I would definitely replace the driveline bearings while you have the track out. If there are wheels in the suspension, inspect those as well. You may want to look at the steering linkage for worn parts, skis and carbides for wear, brake pads and caliper for proper operation, clean and inspect both clutches for worn parts... I'm not sure if that sled has a jackshaft, if it does, I would replace those bearings as well. It's a lot of work and some bucks, but when you are done, you have a sled that will be very dependable.
Rebuilding the fleet!
