Have a '92 Mach 1. Have to replace both idler wheels (centre idler wheels).
I took the bolt off the one side but can't get get the wheel off. A friend of mine recommended buying an idler wheel puller. Are both idlers just supposed to slide off the shaft or is there more to it? Any help is appreciated. Thanks!
depends if you wan to keep them, you might be able to remove them form the bearings then use a bearing puller. Or just smash them off if you dont care.
Some do some dont, look on ebay, your wheel should say on the side what size it is.
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
