i have a mx 470 462 cc with new 34 mm vm dual setup new fuel pump when im at wide open throttle carbs over fill and start flodding float hieght has been set needle and seats cked all work like they supposed to at idle and low rpm its fine but when running at full throttle its leaving a trail fo fuel out the ovwerflow tubes what else can i ck carbs have 170 mains and 35 pilots in them now
already did that still happening then it seems like its running out of fuel but still overflowing it was doing same thing with single carb set up also could it be something with the vacum line
Verify that the Needle vales are actually closing and stopping fuel flow.
If they are not sealing when closed it will either flood the engine or pour out the overflows/vents.
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
