TRA clutch ????????? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 12 (permalink) Old 01-11-2006, 05:52 PM Thread Starter
I have a 98 Grand Touring 500 Liquid
the problem is when you turn the clutch by hand it make a rattling noise from where the levers are, is it normal for these levers to move freely by moving them with a screwdriver should they be attach to some thing. when it running it has a wobbling sound to it
Is the clutch easy too rebuild yourself
and what springs do I use
my Ski-doo has 26000km on it and it should need a rebuild by now stills runs fine except for the wobbling sound
I'm not using it right now
slowpro is offline
post #2 of 12 (permalink) Old 01-11-2006, 06:08 PM
VERY easy to rebuild. Take the long bolt out that holds it to the engine, then just remove the outer half of the clutch. First, make sure the spline on the end of the shaft is OK. Then look at the clutch. There is one large spring in the middle, then there are arms with pucks/springs on the ends. Go to the misc parts section, then click on parts links, then OEM. Find your make/model and click on clutch. That will give you a breakdown of the clutch.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 12 (permalink) Old 01-11-2006, 06:41 PM Thread Starter
DO I need a clutch puller for the removal of the clutch
the dealer said that it is dangerous to take the clutch off
slowpro is offline
post #4 of 12 (permalink) Old 01-11-2006, 06:47 PM
I am the Walrus
letitsnow's Avatar
you can pretty much ignore everything the dealer ever tells you.
here is a step by step disassembly.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
letitsnow is offline
post #5 of 12 (permalink) Old 01-11-2006, 06:50 PM
upersleder's Avatar
on your ski-doo, you need a puller if you take the fixed shive off, otherwise you can take the rest off and service everything without the puller. 9 times out of ten you will get by without it. just to make it easy on yourself, mark the innner and outer shives before you slide it off so you get it back in the same spot.
2003 MXZ 700X
take the warning labels off everything and let the problem sort itself out
upersleder is offline
post #6 of 12 (permalink) Old 01-12-2006, 01:27 AM Thread Starter
I was out looking at the sled and was wondering if I can take the clutch out without having too remove the engine looks like there is not enough room there to slip it out
I notice that the settings are on the number 3 position is this okay or can I move it up 1 or lower it down 1.
what can I used too clean the clutch when removed
slowpro is offline
post #7 of 12 (permalink) Old 01-12-2006, 06:56 AM
Use brake cleaner to clean it. Moving to the next number will raise or lower RPM's by around 200, depending on what way you go with it.
1999 Ski Doo MXZ600
post #8 of 12 (permalink) Old 01-12-2006, 02:25 PM Thread Starter
Can I take it out with out taking the engine out
slowpro is offline
post #9 of 12 (permalink) Old 01-12-2006, 05:36 PM
upersleder's Avatar
its tight, but you should be able to
2003 MXZ 700X
post #10 of 12 (permalink) Old 01-14-2006, 08:48 PM Thread Starter
cleaned the clutch with lite steel wool and some brake cleaner
cleaned the shives
cleaned the secondary
the carb's
the fuel pump
the exhaust valves
I adjusted the clutch numbers from 3 too 4
and what happened is I don't think this is the same Ski-doo that I bought man what a difference this all can make, man this sled can move even for a big heavy Grand Touring and I even got the ski's to lift never done that before
THANKS GUY'S FOR ALL THE HELP
slowpro is offline
post #11 of 12 (permalink) Old 01-14-2006, 08:54 PM
What do you think helped the most?
1999 Ski Doo MXZ600
post #12 of 12 (permalink) Old 01-14-2006, 09:11 PM Thread Starter
I would have to say the clutch cleaning and the exhaust valves made the big difference
slowpro is offline
