I have a used 2000 skidoo summit 700 and the lights only work when you unplug the regulator... we put a new regulator and stator in. yet they still dont work once connected. Any adivce??
Sounds like Yellow/Black is grounded to the frame.
Unplug the regulator and measure with an ohm meter between each side of the regulator connector and frame ground. You should NOT get zero ohms.
If you do, then trace it back on the leg that did.
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
