When your trying to start it and if it does shut off at 1000rpm try starting with the throttle in and letting off when it starts. Also you can just pushing th primer once or twice right when it starts up, thats what usually works for me. Sometimes theres little air bubbles in the lines that dont get out when you first prime it. As for your throttle problem im not sure whats wrong but im sure someone else will. Good Luck!
1995 Chevy k2500 4x4
1996 Skidoo MXZ670
