Old 01-01-2006, 01:09 PM   #1 (permalink)
slug3266
slug3266's Avatar
Hard to Start
Hi,
I have a 1995 Skido Fornula SL 500. It is extremely hard to start for 1st time each day. I have to remove plugs and spray in a little quick start, then it starts, but still takeas about 10 pulls.
I changed the plugs and it is getting a good spark, plunger appears to be getting gas into cylinders. Any Ideas on what I can do ?
Thanks,
Doug
slug3266 is offline   Reply With Quote
Old 01-01-2006, 01:30 PM   #2 (permalink)
BskidooC
BskidooC's Avatar
is it hard to pull over? how does it run after started?
Old 01-01-2006, 03:39 PM   #3 (permalink)
94zr580
super duper member
94zr580's Avatar
does your sled have a choke, or a primer. sounds like your carbs are dirty, cuz its not getting gas till u prim it with starting fluid in the holes which gets the suction going. maybe your fuel pump too.
my sf.com garage
my bikepics page
orleans county snowdrifters
*NEVER a dull moment on SF.com!
Save a cowboy from embarassment. Ride a Motocrosser
2000 kx 125
94 zr580
94 indy xlt
99 xcsp 500
2005 pocket bike
94zr580 is offline   Reply With Quote
Old 01-01-2006, 04:06 PM   #4 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Have you checked compression on each cylinder?
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 01-01-2006, 04:48 PM   #5 (permalink)
speedyvision917
Try holding the throttle down when you start it. Ive got the same problem and that helps to get it started quicker. Just becarefull not to hold the throttle down once its started or bye bye sled. hope that helps
1995 Chevy k2500 4x4
1996 Skidoo MXZ670
speedyvision917 is offline   Reply With Quote
