12-28-2005, 12:17 PM
How deep can these go???
What kind of depth can you ride on the rev's?
12"-18" with no issues?
i know my buddy has an older ski doo mach-z, and it is just about dead in 8-10" its fast, but seems to not do so good in deep snow.
hoping mine will be better
05 800 gsx limited
small bling mods, Woodies picks, and some wax
97 formula Z 583, clutched, and more
Suzuki z-400, cams, header, pipe ect
99 z28 fastest 346 N2O ls1 in the country
Harley, and some other toyes
12-28-2005, 12:23 PM
A god among men
Are you talking about your GSX? My MXZ floats pretty well for a 121" track, it's also really easy to manouver. Just DON'T stop or you're screwed.
12-28-2005, 12:33 PM
Originally posted by BRPforlife
Which REV? The rev is a chassis type not a sled. The 121" will do alright if you know how to ride and don't stop. But if you're going to be doing a lot of powder riding a renegade or summit would be a lot better.
sorry, the rev i was thinking would be pretty close, but i forgot about the summit ect.
i have the gsx 800. when you say alright, do you mean 8" it will be alright, or 12-14 alright? guess it depends on the base, and the type of snow. im pretty new to this stuff. only ridden like 10 times, maybe 200 miles total, only have 50 miles on mine, no snow around yet
05 800 gsx limited
12-28-2005, 01:07 PM
A god among men
Yeah it really depends on the snow and the base. It's not really made for powder riding so don't expect it to perform. It shouldn't have a problem in a foot of powder, as long as you keep your butt moving.
12-28-2005, 01:52 PM
my 500 indy goes through a foot of powder pretty good, starting and stopping, so a newer sled with more power should go through it fine.
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
12-28-2005, 02:49 PM
ok good.
i did the picks already, so that should help on the ice.
i washoping it would do better then the older ones im used to.
05 800 gsx limited
12-28-2005, 03:07 PM
it should.
2007 Honda CRF 230
2003 Honda CRF 230
12-28-2005, 03:12 PM
A god among men
What size lug is on it? 1"?
12-28-2005, 03:19 PM
yes, 1" with a 1.25 stud i believe
05 800 gsx limited
12-28-2005, 05:19 PM
snow depth
I was riding my formula z in 8 to 12 inches it seemed to ride up good but if i stoped or went to take off fast it spun down and hooked up on the ground I have no studs but with studs it will definatly hook up once you spin down. Also found lighter front suspension settings allowed skis to ride up hitting less bumps ect
only problem was I ate a far bit of snow and my hood screens let the belt get wet and start squacking a bit. Snow is way more fun when drifted in and it hardens up only problem is when your stuck your stuck bad
12-28-2005, 05:35 PM
Re: snow depth
so i should try to keep the front skies light so they float? wouldnt that keep the front higher and ther for dry??
05 800 gsx limited
12-28-2005, 06:09 PM
I just found that in deep snow with no real base I was hitting bottom alot and so therefore lighter ski pressure lets the skis ride softer saving carbides from rocks. But I would crank them back up on packed trail for stability and steering made no real difference as far as how much snow was thrown around I was in really deep fluffy stuff. You will have to try it and adjust from there to see what works for your conditions.
12-29-2005, 09:01 AM
Re: so i should try to keep the front skies light so they float? wouldnt that keep the fr
cool, im going to have to ride it. If it ever snows!!!
05 800 gsx limited
12-29-2005, 02:56 PM
I am the Walrus
12" should be no problem if you know what your doing.
What does your LS1 run in the 1/4?
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
12-29-2005, 03:53 PM
cool, i hope it does. not sure i know what im doing tho. lol
i have been riding quads for 15 years, and jet ski's for more then that, so im guessing i will be ok.
M|y car went 9.40 @ 143 with a stock cube motor 346 ci
im building a 402 this winter, lossing about 200 pounds and adding about 200 more worth of the spray, i should be 800-1000 rwhp and 3200 pounds so mid 8's im hoping for, then maybe light the wick a little more.
05 800 gsx limited
