Old 12-25-2005, 09:56 PM   #1 (permalink)
dahlfan
Damn formula Plus X
I have a 1992 Formula Plus X.
Last year I hit a manhole cover several times and messed up the front end.
The trailing arm was bent out of shape and the lower right are is cracked and wont hold the ball joint that connects to the trailing arm.
This sled is a limited edition and only 250 were made.
I found out that the parts have been discontinued.
I found a new trailing arm but cant find the lower arm.
I am fairly new to snowmobiling. ANy idea where I can find this part.
Last year I called many salvage yards with no luck. I also checked with several dealers and no luck there either.
Any Idea where I can find this part.
If I would take the sled to my local dealer what would they do to repair it or would they just tell me that they can't fix it.
Any help would be great
Merry Christmas
Mike
dahlfan is offline   Reply With Quote
Old 12-25-2005, 11:43 PM   #2 (permalink)
kdf baja
Sledneck
kdf baja's Avatar
im sure it has common parts, find out what the chassis name is, and im sure parts from similar sleds will be interchangeable
also, how did you manage to hit the manhole cover SEVERAL times??
72 baja bug...slingers n straightpipes
74 VW bus
71 chevy vega V8 project
89 GMC Suburban 4x4
kdf baja is offline   Reply With Quote
Old 12-26-2005, 07:09 AM   #3 (permalink)
The formula plus X is the same chassis as the Mach 1.
Old 12-26-2005, 01:09 PM   #4 (permalink)
mx and sled 41
mx and sled 41's Avatar
i dont know where you are located, but in ontario theres a place called J.T.'s and they have a fiarly good selection of USED parts, but for new parts either a dealer or maybe like a royal distributing will stock them.
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
mx and sled 41 is offline   Reply With Quote
Old 12-26-2005, 06:41 PM   #5 (permalink)
dahlfan
I've checked with dealers and they dont have the part and say that Ski-Doo discontinued the part.
I am going to call the manufacturer tomorrer to see if the part is used on any other model that they still make parts for.
I hope this works.
I miss my sled....
Old 12-26-2005, 07:43 PM   #6 (permalink)
Go to www.hlsm.com and find the parts on the microfiche. Let us know what you need. Maybe someone can help you.
Old 12-26-2005, 09:54 PM   #7 (permalink)
dahlfan
The part I need is the right Lower arm
In the front suspension/Ski
1992 Formula Plus X
Ski-Doo part no. 506 1095 00 Lower arm right side
Old 12-26-2005, 10:30 PM   #8 (permalink)
My aftermarket catalog lists them all being the same.Mach 1 Formula plus, etc.
Old 12-27-2005, 09:31 AM   #9 (permalink)
dahlfan
What catalog did you find that in.
I am not having any luck
Mike
Old 12-27-2005, 12:04 PM   #10 (permalink)
Oops....I was looking at the wrong part. But...I called a dealer here in NH who is awesome with this stuff. He said that the difference between yours and a Mach 1 is there was an extra hole drilled in yours. You may want to order one for a Mach 1 and drill it, or remove your left side one and have one made like it. They WERE discontinued quite a while ago. You may want to try www.alssnowmobile.com and see if they might have a used one for it.
Old 12-28-2005, 09:05 AM   #11 (permalink)
01MXZ800
01MXZ800's Avatar
HOUDONS SALVAGE should have what you need you have the "prs" chassis. what sucks is i just got rid of my old formula parts and i had 2 of them.
01 MXZ 800
Old Erie Riders Snowmobile Club
