Old 12-25-2005, 07:18 PM   #1 (permalink)
kdf baja
Sledneck
kdf baja's Avatar
risers
how big of risers can i get without any extentions, and minimal mods, such as re-routing the brake hose, im thinking 3-4 inches. got some xmas money to get them, and definitley need them, my back is killing me
72 baja bug...slingers n straightpipes
74 VW bus
71 chevy vega V8 project
89 GMC Suburban 4x4
kdf baja is offline   Reply With Quote
Old 12-25-2005, 07:20 PM   #2 (permalink)
kdf baja
Sledneck
kdf baja's Avatar
also, i would like to mount a temp guage, one for each side of the head. what brand should i go with, and what will one of these cost? whats better mechanical or electrical?
thanks
74 VW bus
89 GMC Suburban 4x4
Old 12-25-2005, 07:55 PM   #3 (permalink)
JEFFH
JEFFH's Avatar
Most sled will go 3" with no mods to the cables.
JEFFH is offline   Reply With Quote
Old 12-25-2005, 09:45 PM   #4 (permalink)
94zr580
super duper member
94zr580's Avatar
yup 3, i got 3.5 tho.
my sf.com garage
my bikepics page
orleans county snowdrifters
*NEVER a dull moment on SF.com!
Save a cowboy from embarassment. Ride a Motocrosser
2000 kx 125
94 zr580
94 indy xlt
99 xcsp 500
2005 pocket bike
94zr580 is offline   Reply With Quote
Old 12-26-2005, 01:17 PM   #5 (permalink)
mx and sled 41
mx and sled 41's Avatar
how did you get the extra half inch? btw, nice zr!
"slidin rear, back window, so it's an easy reach to where my cooler keeps 'em iced down cold"
truck- 1998 chevy 1500 extended cab 4X4 Z71 package fully loaded 5.7L vortec
sled- 1989 Polaris Indy 500 Special (blue clutch spring) FOR SALE!!!!!
2007 Honda CRF 230
2003 Honda CRF 230
mx and sled 41 is offline   Reply With Quote
Old 12-26-2005, 03:13 PM   #6 (permalink)
dobbs
www.315er.net
dobbs's Avatar
4.5" no ext. req.
1997 MXZ
could have gone another inch
cut all the cable ties under the hood, pull, retie
dobbs is offline   Reply With Quote
Old 12-26-2005, 03:49 PM   #7 (permalink)
kdf baja
Sledneck
kdf baja's Avatar
cool, thanks guys. i think ill go with a 3 inch, thats just about what i was looking for.
what about a temp guage?
thanks again
74 VW bus
89 GMC Suburban 4x4
Old 12-26-2005, 03:58 PM   #8 (permalink)
94zr580
super duper member
94zr580's Avatar
what i meant was most people can only go 3"s. mine was able to go 3.5. thanks for the compliment
my sf.com garage
my bikepics page
2000 kx 125
94 zr580
94 indy xlt
99 xcsp 500
2005 pocket bike
Old 12-26-2005, 05:48 PM   #9 (permalink)
mx and sled 41
n/p, im thinking about doing them on my indy 500, how hard are they to install? are they just bolt on? and can i use the stock bars on them too?
2007 Honda CRF 230
2003 Honda CRF 230
Old 12-26-2005, 07:04 PM   #10 (permalink)
dobbs
www.315er.net
dobbs's Avatar
it's diff. for manufactures and sometimes models.
Ski-doo's have flat plates for 4 holes or another bar welded on at the top of the column to form a tee.
Old 12-26-2005, 07:39 PM   #11 (permalink)
mx and sled 41
so basically they just bolt on to where the bars usually go? and do i have to buy aftermarket bars for them or can i use the stock ones? also, how much did yours cost?
2007 Honda CRF 230
2003 Honda CRF 230
Old 12-26-2005, 08:14 PM   #12 (permalink)
dobbs
www.315er.net
dobbs's Avatar
don't look at mine for an example, it's kind of home made.
You have to basic types, the articulated and the block.
The block
Extends your steering column, the bars rise but they stay on the same angle as the steering column so they get close to you. There is ususally a plate at the top of the steering column which acts as the bottom 1/2 of the clamp, then the bars, then the top of the clamps. The riser block goes between the bottom plate/clamp and the bar. Longer bolts are used to sandwich the thing togther.
The articulating riser.
For this the top of the steering column need to be a bar like your handle bars, I bolted in a piece of 7/8" stainless rod or you could bolt on one of these
Your riser can then pivot front to back on the lower tube so the riser goes up instead of towards you.
hope that wasn't to confusing
Old 12-26-2005, 08:17 PM   #13 (permalink)
dobbs
www.315er.net
dobbs's Avatar
You keep your stock bars.
I used a riser of a rev i got for $20. I then cut it to fit over the stock clamps so i didn't have to buy one of those adapters shown above. I used the stock clamps to hold the 7/8" rod.
Old 12-26-2005, 08:22 PM   #14 (permalink)
94zr580
super duper member
94zr580's Avatar
thats a good idea dobbs. u got a pivot riser for your plate style bars by sticking a 7/8" piece of rod in the bar holder then attached the riser to that piece of rod, right? heres my risers that i made from scratch (i just made the riser block then bolted it inbetween my column plate and my bar mount, and those are renthal bars, and my cover for the pad flew off )
my sf.com garage
my bikepics page
2000 kx 125
94 zr580
94 indy xlt
99 xcsp 500
2005 pocket bike
Old 12-26-2005, 08:35 PM   #15 (permalink)
SSnthe10s
Head horsepower junkie
SSnthe10s's Avatar
thanks
just do a single coolant temp gauge.
1995 Indy RXL modded....-Sold
SSnthe10s is offline   Reply With Quote
Old 12-26-2005, 08:40 PM   #16 (permalink)
dobbs
www.315er.net
dobbs's Avatar
Yeah, that's all i did. Normally that won't work unless you get the risers that look like two dogbones (no middle to hit the clamps).
riser
Old 12-26-2005, 08:58 PM   #17 (permalink)
mx and sled 41
do you think i could take a piece of rectangular metal and just weld it on to the bottom of my clamps with some modifications? or would that not work?
2007 Honda CRF 230
2003 Honda CRF 230
Old 12-26-2005, 09:24 PM   #18 (permalink)
SSnthe10s
SSnthe10s's Avatar
i think it would just be easier to spend the 20bux and buy the 2" riser block.
Old 12-26-2005, 09:37 PM   #19 (permalink)
mx and sled 41
i didnt realize that was all they were... thanks though ill probably end up doing that then.
2007 Honda CRF 230
2003 Honda CRF 230
Old 12-26-2005, 10:07 PM   #20 (permalink)
dobbs
www.315er.net
dobbs's Avatar
Non-Pivot
Pivot
pivot requires one of these
