Old 12-24-2005, 09:30 PM   #1 (permalink)
formula 583
Formula z 583 starting problem
i have a 1997 formula z 583, it has a extremely hard pull to it. someone had mentioned to me that it could be from a crack in the crank case and oil was leaking into something and thats why it so hard to pull/start. anybody heard of this? if not anyone know what is wrong with it?
thanks,
DR
formula 583 is offline   Reply With Quote
Old 12-26-2005, 05:34 PM   #2 (permalink)
tpfairbanks
tpfairbanks's Avatar
583 leaking oil
i have had 3 583 and they all leak oil.
one into the muffler, one a little from the crank somewhere and the third from the crank somewher like a sieve.
I don't know why but the last one could be from putting it in to the lake and maybe cracking the crank
I will let you know why if i can ever figure it out, if any one knows let me know
Thanks
tpfairbanks is offline   Reply With Quote
Old 12-30-2005, 11:30 PM   #3 (permalink)
BskidooC
BskidooC's Avatar
ive heard of that happening but I dont know what you can do about it
Old 12-31-2005, 06:37 AM   #4 (permalink)
Might just be hard compression. Does it pull much easier wit hthe plugs out? With the belt removed? Try to eliminate other things first.
Old 12-31-2005, 01:56 PM   #5 (permalink)
letitsnow
I am the Walrus
letitsnow's Avatar
compared to other sleds (zl440, xlt580, zr580, vmax 600), my 583 has real high compression.
My Pics
1999 Arctic Cat ZL 440
1994 SkiDoo Mach 1 583
1995 Honda CR 125R
1982 Camaro w/ 355
Old 12-31-2005, 03:01 PM   #6 (permalink)
94zr580
super duper member
94zr580's Avatar
yea, his ^^^ 583 is a b*tch to pull over.
my sf.com garage
my bikepics page
orleans county snowdrifters
*NEVER a dull moment on SF.com!
Save a cowboy from embarassment. Ride a Motocrosser
2000 kx 125
94 zr580
94 indy xlt
99 xcsp 500
2005 pocket bike
94zr580 is offline   Reply With Quote
Old 12-31-2005, 09:07 PM   #7 (permalink)
letitsnow
I am the Walrus
letitsnow's Avatar
but it starts first pull every time, except the first start of the season, i had to pump the gas up. i felt like i had worked out real hard the day after.
My Pics
1995 Honda CR 125R
1982 Camaro w/ 355
Old 01-01-2006, 02:42 PM   #8 (permalink)
formula 583
When i take the plugs out the sled is fairly easy to pull over. I havent taken the belt off because i have had hardly anytime to work on it plus there is no snow around me.
Thanks for the help,
DR
Old 01-04-2006, 04:45 PM   #9 (permalink)
tpfairbanks
583 hard to pull
My 1994 583 pulls a lot harder than my 2001 800 summit. The reason is mainly the recoil. If your 1997 has a old recoil (small diameter and black) and not the new larger diameter metal ones that will make a big difference. The compression is a big part as well but not all the reason because the pull is not jerky through the cycles like my 800. I suspect the rotary valve creates the friction difference. I don't know how the rotary valves are lubricated but maybe that is the problem, the only thing is my '94 583 has pulled hard from the beginning harder than any motor i have ever pulled over!
My '94 583 also starts the first pull but only if it is fast enough. At -5 i have to pull it out slow 3 x before i can pull it fast enough to start it.
Just think you are getting stronger with every pull!
rotary valve
Old 02-16-2006, 09:25 PM   #10 (permalink)
TopOfTheRockies
Rotary Valve Lubrication
My '96 583 is really hard to pull too, glad it starts on the first or second pull. I'll be looking for the newer larger diameter metal one soon.
Here is a link that shows two sources on how the rotary valve gets lubricated. It shows a marine engine, but, the rotary valve looks just like the one on my 583 and my 500.
It looks like it gets lubricated when the oil injectors inject their oil.
Another source, if your burning too much oil, is an angular tube, item 10 on the quinnsmarina link, that comes from a small oil tank. Looks like it oils the main bearings in the engine. If the oil seal is bad, it could also oil the rotary valve.
http://www.quinnsmarina.ca/seadoopar...otaryvalve.htm
TopOfTheRockies is offline   Reply With Quote
