I had a 377 in an 80 MotoSki (same as SkiDoo). I simply removed the pump, tank, lines & disconnected the cable. The 2 injector lines went to 2 very small nipples (he said nipples!! heh, heh) on the underside of the intake manifold. Just use 1 piece of hose & connect those two nipples together, so they don't suck air. Premix at 50:1 & you should be OK
