problem with my 86 formula mx
I Just pulled the sled out for the new winter season. Did all the necessery things, cleaned carbs, new belt, spark plugs, new gas. Anyways i got it running. Started on the 5 pull. Not bad for a 19 year old sled. anyways. right when you start it up it idles at about 2 grand then after a couple seconds it goes up to about 4000-5000 rpm and just stays there. I have to keep my hand on the brake to prevent the track from just spinning. I checked for an airleak there the carbs conect to the rubber boot and those are fine. throttle cable is moving freely, not binding or anything. gas is on. when i take my hand off the brake the track will spin and the rpms will then continue to go up.
does anyone know where i can start to look for this problem? i have had this thing for about 10 years and it has never done this before.
im stumped.
jeff
