adjust springs 95 xlt - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 02-10-2014, 07:56 PM Thread Starter
Quoted: 2 Post(s)
hey guys , trying to adjust rear spring tension, sled is on the floor, tried turning cam ,wont move at all , think in i have to un load suspension , or cam is stuck on shaft , afraid if i whack it , its plastic its gonna break, any ideas
polaris754 is offline
post #2 of 5 (permalink) Old 02-10-2014, 10:29 PM
XLT Spartan's Avatar
Turn off the fuel, put the sled on it's side, hit the treads with a lot of wd40. Then use a screwdriver in one of the notches and a hammer to knock it loose. Take your time and don't hit it to hard. It will eventually free up.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
XLT Spartan is offline
post #3 of 5 (permalink) Old 02-11-2014, 12:06 AM
Quoted: 7 Post(s)
There aren't any threads in there. The block slides onto a shaft and a fastener cap is pressed onto the shaft to hold block on. As mentioned though putting some type of penetrating oil will help it turn. I usually lift long leg of spring out of its holder to release s[ring tension and then use 13/16" socket or spark plug wrench to turn the block. Can either do it flat on ground or tipped on its side.
steepndeep is offline
post #4 of 5 (permalink) Old 02-11-2014, 08:19 AM
My bad. I thought he was asking about the shock coil over, not the rear torsion springs.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
post #5 of 5 (permalink) Old 02-11-2014, 06:35 PM Thread Starter
Quoted: 2 Post(s)
soaked them this morning with pb blaster heated with hair dyer , them suckers are not moving, kinna think they have been in that happy spot since 95 ! lol well im going to check if i can get a set now , if so im just going to break them off thanks fer the help
