95 xlt hand warmers - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 4 (permalink) Old 02-09-2014, 03:00 AM Thread Starter
Quoted: 2 Post(s)
95 xlt hand warmers
took sled out for its first long ride yesterday, the hand warmers are working the thumb warmer isnt what should i check there ,also even though i can feel the heat on the grips they dont seem hot enough , might have been too dam cold as well , is there a resistor some where that may be a prob? my lights dim when i turn them on , but not much , any help thanks, dose have a high and low position,
polaris754 is offline
post #2 of 4 (permalink) Old 02-09-2014, 05:53 AM
Lank's Avatar
I had the same problem. The first thing I did was, I took the two plastic pieces off the handle bars the first piece has five plastic screws, unscrew them a bit then pull them out then you need to lift it up and pry it off. The next piece has another four or five plastic screws/retainers and 4 regular Phillip head screws. Once you have that off, you will see the thumb warmer Just plugs in to the harness. Unplug it, get a volt meter set it to AC start the machine, turn it on and see if you have power. If you have power, your thumb warmer is burnt out. If you have no power, work your way back (switch, wiring). On mind, the thumb warmer was burnt out. The dealer wanted $50 for a new one, I went to our local snowmobile scrapyard and took one off a XLT and paid five dollars.
Lank is offline
post #3 of 4 (permalink) Old 02-09-2014, 06:22 AM Thread Starter
Quoted: 2 Post(s)
thanks for the info lank ,do u have to solder it in ?
post #4 of 4 (permalink) Old 02-09-2014, 07:14 AM
Lank's Avatar
No it plugs in to the harness, it is one piece, the Throttle lever and heating element. You can't remove the heating element from the throttle lever.
Lank is offline
