2000 XC600 exhaust compatibility - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-20-2013, 07:45 AM   #1 (permalink)
I have a 2000 xc600 with a huge rusted out hole in the exhaust pipe. What years/models have the same exhaust?
belome is offline   Reply With Quote
Old 02-20-2013, 07:48 AM   #2 (permalink)
One that I'm currently looking at is from a 02 XCR EDGE 800, it looks the same in photos.
Old 02-20-2013, 07:55 AM   #3 (permalink)
Also, I'm new to Polaris, is my sled considered an Edge chassis or ???
Old 02-20-2013, 07:56 AM   #4 (permalink)
I also found a used exhaust for 1998 XC600.
Old 02-20-2013, 08:59 AM   #5 (permalink)
i would be riding but...
sledder1985's Avatar
your sled is not an edge. i would like to go out on a limb here and say the 800 one wont work. i would just try to find one from your same engine size and as close to the same year. i dont know for sure what years fit and what mufflers will work with that motor but maybe someone else does...?
2002 Polaris XC SP 600
2004 Polaris Predator 500
sledder1985 is offline   Reply With Quote
Old 02-20-2013, 10:55 AM   #6 (permalink)
Klein
AKlein57's Avatar
Re: 2000 XC600 exhaust compatibility
One quick question does it have the variable exhaust valves. If it does it is a small block an you can use a pipe from a 01 to 05 600. If it doesn't have exhaust valves it is a big block 600 and you can use a pipe off of a 600 from i think 97 ish to 99 along with a 600 from 00 with the same engine.
Klein
AKlein57 is offline   Reply With Quote
Old 02-20-2013, 11:13 AM   #7 (permalink)
Mine does have variable exhaust valves.
Old 02-20-2013, 01:04 PM   #8 (permalink)
joshkidner's Avatar
so you need to find one from the same body style, same engine size, and one that came of another sled with VES. Show us a pic, I believe the edges were the ones with VES and genII was nonVES. before the edge and genII was the evolved, and before that was agressive, and before that was wedge, which is what my sled in my profile pic is.
Old 02-20-2013, 01:39 PM   #9 (permalink)
Klein
AKlein57's Avatar
From my post above.
Klein
Old 02-20-2013, 01:53 PM   #10 (permalink)
Browse
Find your sled, go to the exhaust section. On the left window where the part numbers are, scroll that window to the left. You will see a "usage" tab that shows which sleds used that exact part number.
Old 02-20-2013, 03:00 PM   #11 (permalink)
Thanks dan, that is pretty cool. Oddly, the Y-pipe and Silencer both show they are used in other year/makes but the pipe itself says my sled only. I sure hope that is wrong.
