Weak Suspension - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 6 (permalink) Old 02-19-2013, 11:40 PM Thread Starter
Weak Suspension
I've got a 98 XC 600. Got a fox shock in the rear (that's how I bought it) and for some reason it sits really low. Sometimes just from its own weight it will sit and bottom out or be really low, other times like maybe after a ride it will stand up better. My thoughts are that the torsion spring is weak but I would like some other opinions. Any thoughts? Thanks!
snomo55 is offline
post #2 of 6 (permalink) Old 02-20-2013, 09:22 AM
Quoted: 7 Post(s)
I would recommend that you first pull your suspension and pull all the cross shafts and clean all of the old grease and any corrosion out first. Then re-grease and re-install and check. Also check to see if your shock needs rebuilt.
steepndeep is offline
post #3 of 6 (permalink) Old 02-20-2013, 09:42 AM
XLT Spartan's Avatar
Weak Suspension
Sounds like your shock could be toast. Like steep said, pull the skid. If you can easily compress the shock by hand you have your answer. Depending on where you ride, if the sled feels like it is bucking up and down in bumps it is because you are a only relying on the rear tortion springs with no shock dampening.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
XLT Spartan is offline
post #4 of 6 (permalink) Old 02-20-2013, 11:17 AM
Quoted: 102 Post(s)
What setting do you have the springs on? If it's adjusted to the stiffest setting and it won't hold the rear of the sled up, it's very likely that the springs are shot and need replaced. The other maintenance tips posted by steepndeep and xlt spartan is also sound advice and I would do those also.
BC_Dan is offline
post #5 of 6 (permalink) Old 02-20-2013, 10:04 PM
Quoted: 7 Post(s)
One thing that I forgot to mention is that sometimes the shaft gets bent and allows it to bind in the tube. Make sure that all shafts that turn are straight.
post #6 of 6 (permalink) Old 02-21-2013, 09:56 AM
Waiting for snow in PA
re
What BC Dan said! It should sit up without any shock on its own. If not, the springs are probably collapsed and need to be replaced.
Thanks! TJ
2012-13--- 264 miles @ Laurel Highlands PA
1996 Polaris XLT with Xtra12
1996 Polaris Indy Lite GT
94sportwithkids is offline
