Another chain oil question - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-08-2013, 10:10 AM   #1 (permalink)
I have a 2000 xc 500. Just pulled the chain cover, dropped the oil put a new gasket in and put in back together. Went for a long ride yesterday and checked it about every 10-15 miles. Everytime it was blackish with small shavings on it- no big pieces or anything. Let it sit over night same thing, checked this morning blackish- no sludge or anything just a lot dirtier than I would have thought. Is this normal? Sled ran great. Oil is polaris synthetic.
pokman is offline   Reply With Quote
Old 02-08-2013, 10:38 AM   #2 (permalink)
Not sure on color but shavings are normal because the shavings come off the gears and their is a magnet on the dipstick that is why their are shavings on it
Sent from Snowmobile.com App
Polaris55094 is offline   Reply With Quote
Old 02-08-2013, 12:03 PM   #3 (permalink)
edgex800ves
edge800ves's Avatar
when you were in there was your gear solid(as in no play in it) if it turned black it could be a sign your bearing seal is gone. Not positive on that but I use atf and it always stays red.
2012 IQ LXT 550F
2002 Edge X 800
1990 Indy 500 SKS
Old 02-08-2013, 12:38 PM   #4 (permalink)
Everything looked and felt great in the chaincase. Polaris550 I am not so much worried about the shavings, I did realize about the magnet-more so about the color seemed to be dirty right away for being brand new.
Old 02-08-2013, 06:41 PM   #5 (permalink)
xflyer53's Avatar
Might just be old oil and sediment working out of your chain. I would change it a couple more times over the season and see if it starts clearing up.
'92 Indy 650
'95 Indy XLT 600, plastic skis, skid plate, cobra windshield, XTRA 10, full Fox package, 1" riser
xflyer53 is offline   Reply With Quote
Old 02-08-2013, 09:26 PM   #6 (permalink)
When I change my oil, I remove the cover and spray the whole case/sprockets/chain with WD40 or brake cleaner. There are a lot of nooks and crannies in the chaincase that hold sediment and junk. If the chaincase isn't clean, the new oil picks that stuff up pretty quickly. It doesn't take much to make the oil look dark.
Old 02-09-2013, 10:24 PM   #7 (permalink)
BC, what oil do you run in your chaincase?
ken3296 is offline   Reply With Quote
Old 02-10-2013, 12:59 AM   #8 (permalink)
I use Polaris synthetic chaincase oil in all my sleds.
Old 02-10-2013, 07:13 PM   #9 (permalink)
joshkidner's Avatar
I run amsoil full synthetic. if you are at all worried about the shavings, check chain tension. If it was too tight that would explain a bit too many shavings. rule of thumb is as tight as you can get it using only your hands strength, then 1/4 turn back out.
