1989 Polaris 650 speedo not working? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-29-2013, 06:24 PM   #1 (permalink)
I have a 1989 Polaris Indy 650 and the speedo is not working. Checked cable and it is connected good up to the speedo gauge. Can't get to the other end of the cable because it is not visible. What do you think is wrong? Will I have to take the engine out to get the the other end of the cable?
superrc84 is offline   Reply With Quote
Old 01-29-2013, 07:45 PM   #2 (permalink)
http://www.snowmobileforum.com/engin...se-things.html
Read this first.
The other cable end terminates behind and below the secondary clutch at the speedometer gear adapter. Removal of the engine for repair is not required, but removal of the rear suspension and driveline likely will be.
Old 01-30-2013, 02:00 PM   #3 (permalink)
rgoers's Avatar
Yep - Broken speedo keys are usually a good indicator that the bearing is toast.
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
Old 01-31-2013, 07:26 AM   #4 (permalink)
found the problem. The cable inside the speedometer cable was cleanly snapped in half lol
Old 01-31-2013, 09:28 AM   #5 (permalink)
easy fix
you have to like that!
Old 01-31-2013, 09:59 AM   #6 (permalink)
o yeah got a new cable and have it on works good now thanks for the help
Old 01-31-2013, 04:42 PM   #7 (permalink)
rgoers's Avatar
Good for you! That's the best kind of speedo issue. My '04 RMK was exactly the same!!! I re-routed the speedo cable when I replaced it - making sure there were no tight bends when the cowling was closed.
Old 02-04-2013, 06:10 PM   #8 (permalink)
PolarisBlood's Avatar
I had the same issue with my 86 Indy trail. part of the cable was missing but the Key was intact.
easy fix. it works great now. I also made sure to lube the new cable. I used Liquid wrench with Teflon. it works great.
'97 Indy XLT limited - Sweet sled
'95 Indy XLT (my first Triple)
'91 Indy Classic - Stock - rebuilt clutch. - FOR SALE $600
'86 Indy 400 - Not Stock - FOR SALE - $800
'86 Polaris SS440 - FOR SALE $300 -
'86 Indy Trail - FOR SALE - $400 good beater sled!!!!
'85 Indy 400 - "WE WILL REBUILD IT!"
'79 Polaris Gemini 250 (244 Twin)
'78 Arctic Cat El Tigre 6000 (440 L/C)
'73 Polaris Colt 294S/S (F/A) - FOR SALE $300
PolarisBlood
PolarisBlood is online now   Reply With Quote
