blowin orings
i have a 03 pro x 800 and the top end was just redone but i road it 5 miles and it started smoking and found out that it was burning antifreeze so i had a new thermostat and orings installed and went to ride the other day and the same thing happened to the same cylinder. i did a compression check and that side had almost 200 psi so whats going on?
If you cant fix it with a hammer then you've got an electrical problem
