track replacement ?'s
I'm putting a new track my 95 xlt. I have it down to where i am about to pull the drive shaft out. I thought this was going to be a breeze, until i found out that with the 4 drive cogs you can't just easily slide the shaft out like you would be able to with the 2 cog driveshaft.
So i just want to doublecheck something. Looking at it, it appears that i have to remove the chaincase to gain enough clearance to pull the shaft out. Am i right about this or is there an easier way that i am not seeing.
96 Polaris XLT Indy special
73 Arctic Cat Cheetah 440
