Snowmobile.com - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-10-2013, 05:40 PM   #1 (permalink)
Snowmobile.com
I just bought a 93 Polaris indy storm 750 Triple I put 250 miles on already but was having some mid range issues as far as bogging down I decided to change spark plugs NGK BR9ES and now the sled idles at 4000 rpm and will not drop down with the old plugs it was at 1000 does anybody have any suggestions
Andy/ Sandusky is offline   Reply With Quote
Old 01-10-2013, 06:06 PM   #2 (permalink)
I would start with cleaning your Carbs
Old 01-10-2013, 06:13 PM   #3 (permalink)
The carbs were fogged out when it was put away last time but thanks for the advice this is all new to me and I appreciate the advice
Old 01-10-2013, 06:29 PM   #4 (permalink)
[QUOTE=Andy/ Sandusky;532295]I just bought a 93 Polaris indy storm 750 Triple I put 250 miles on already but was having some mid range issues as far as bogging down I decided to change spark plugs NGK BR9ES and now the sled idles at 4000 rpm and will not drop down with the old plugs it was at 1000 does anybody have any suggestions
if I'm running around 50 or 60 miles per hour for a bit and go to crack the throttle it will just bog and not accelerate but if I let off the throttle and then punch it I can get over100 MPH
Old 01-10-2013, 07:34 PM   #5 (permalink)
Sounds like your flooding the engine. Could be your jetting is wrong, and your carbs could be not adjusted properly for the idle. But they could also be dirty and need cleaning.
I know you said it was fogged, but that doesn't mean your carbs can not be dirty or have a clogged passage or your float sticking causing it to flood the engine and cause the bogging.
To me it sounds like a carb issue.
Old 01-10-2013, 09:41 PM   #6 (permalink)
Try turning the air screws in 1/8 of a turn at a time to see if you can get the idle to come down. That will also help with a low end bog.
If you turn the air screws all the way in (1/8 turn at a time) with no change, that indicates the air or fuel passages to the pilot jets are clogged. That's very common and a good reason to clean the carbs yearly just prior to the start of the season. With the garbage gas we get these days, it's a wonder sleds run at all
Old 01-10-2013, 10:09 PM   #7 (permalink)
Josh Kidner's Avatar
Idle should be 1800-1900rpm. Good luck!
Old 01-16-2013, 04:56 AM   #8 (permalink)
Thanks for all of your advice turned out to be loose throttle cables can't wait to get some snow to truly test
