98 ultra help - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
post #21 of 78 (permalink) Old 01-13-2013, 10:54 AM
Mighty Quinn's Avatar
Thats true,Your right(Ultrafrozen) those were the better years which he has for the water pump with the oil res.eleminated & open to the engine fuel & oil
Mighty Quinn is offline
post #22 of 78 (permalink) Old 01-13-2013, 11:28 AM Thread Starter
dhridenh's Avatar
Should I at least crack her open and take a peek or should I leave it the engine has not run in 2 years also I have corrosion on my Bosen reeds the mettle part these are the first Reed sets I have had my others sleds don't have them should I sand off the corrosion off them
dhridenh is offline
post #23 of 78 (permalink) Old 01-13-2013, 12:19 PM
Not sure what your cracking open to take a peek of? Take a pic of the boysen reeds with the corrosion on them? Boysen reeds are probably one of the best ! Someone else upgraded ,perfect! If they are in good shape?
post #24 of 78 (permalink) Old 01-13-2013, 01:04 PM Thread Starter
dhridenh's Avatar
The water pump I was going to open it up to see if there are any problems and the reeds them selves look good the plastic and stuff it's the mettle cage on ether side that has like white corrosion on them I think a buffing with a soft wiz wheel will fix them up I will take pics in a little bit here
dhridenh is offline
post #25 of 78 (permalink) Old 01-14-2013, 06:44 AM
Well... (dhridenh) the water pump gear is something that can be visually inspected,but the only way is removing it from the block . Then you can check to make sure the plastic gear is not wore to much & it moves freely.There is a weep hole on the bottom of the water pump ,this lets you know if the internal seal is leaking,(if the machine was running that is .)There may be signs of it leaking in the past, antifreeze stains rivering down to the bottom of the pump on the outside of the casing from the weep hole?
The white corrsion your taking about probably could be scuffed up with scoth brite pad ,depending on the location on the reed intake,pic would be nice.
post #26 of 78 (permalink) Old 01-14-2013, 03:44 PM Thread Starter
dhridenh's Avatar
Yea the reeds I used 220 grit sand paper on the steel to remove the corrosion from the looks off it the engine has been rebuilt 1 time before as well the crank has what a peers to be a fresh gasket on it
dhridenh is offline
post #27 of 78 (permalink) Old 01-14-2013, 07:51 PM
If theres no sharp edges should be ok for the reeds.Personaly I would now finsh it with 400 to a 600 grit ,but thats just me. I'm not quite sure how you are adentifing that the motor has been rebuilt before? Fresh gasket? You meen along the two crank halves ? I hope not! that does not require a gasket ,just a special gasket sealer to mate the two halves together. If it is light gray in color ,could still be factory sealant?
post #28 of 78 (permalink) Old 01-14-2013, 08:05 PM Thread Starter
dhridenh's Avatar
yea it looks like a rtv almost its not a gasket as in paper or metal but yes. also some one has had the jugs and had smoothed out the exhaust ports on the 2 older jugs its very slight not really that noticeable but u can tell.
anyways i have cleaned the engine and sanded the pto shaft were the clutch mates to the engine. had surface rust.
dhridenh is offline
post #29 of 78 (permalink) Old 01-14-2013, 08:08 PM
How are the other two pistons & in the cylinders anyway? Any scoring on the exhaust , or intake side of the pistons ? Check through to ports,& down the cylinder walls . This corrosion thing is kinda got me worried for the bottom end ?
post #30 of 78 (permalink) Old 01-14-2013, 09:37 PM Thread Starter
dhridenh's Avatar
The other 2 look great man te reeds I thing has the corrosion because it was in a porch opened up with nothing covering the head or the intake but looks good turns over free no play in the crank or in the rods I am doing all 3 pistons on it along with new upper bearings as well
dhridenh is offline
post #31 of 78 (permalink) Old 01-15-2013, 06:20 AM
I Hope you'll be getting matching pistons Polaris OEM,SPX,SPI & Wiseco ? If the factory crosshatching is still noticable in the cylinders ,sometimes you can get away without doing a slite honing,but my recondmodation would be to order a (FLEX-HONE) ball hone spacific to that cylinder bore from Flex- Hone I think it is a 240 grit aliuminum oxside spacific for Nicasil cylinders.Go on line & you will find the site ,email your infomation & they will help you to order the right one Best 40 bucks I spent.
post #32 of 78 (permalink) Old 01-15-2013, 10:26 AM Thread Starter
dhridenh's Avatar
I just ordered 3 spi pistons oem size 66.50 mm I can see the cross hatching very well but I think I will hone them
dhridenh is offline
post #33 of 78 (permalink) Old 01-15-2013, 10:28 AM Thread Starter
dhridenh's Avatar
Yea what's the web site
dhridenh is offline
post #34 of 78 (permalink) Old 01-15-2013, 07:57 PM
Just like i said,( FLEX HONE ) they specialize in machining tools.Honeing will be the best for the top end break in .
post #35 of 78 (permalink) Old 01-16-2013, 08:25 AM
I'm sorry,my mistake it's (EngineHones.com) The product is made by FLEX-HONE . Click on for Nikacil hones aluiminum oxcide ,then go down the list till you find Item desription (2-5/8 FlexHone Tool 320 grit AO -169) Item No.# 258320AO .That will be the one you will need. It is for a 66.6 mm bore which it is a size showing (67mm) ,slightly bigger than your bore . Hope this helps?
post #36 of 78 (permalink) Old 01-18-2013, 11:24 PM Thread Starter
dhridenh's Avatar
well i have gotten the heads on and the jugs i need to grab my crows feet from work to fully torque the jug bolts on it but now i have a oil line that goes t the crank case but i have no nipple or anything that it goes on
dhridenh is offline
post #37 of 78 (permalink) Old 01-19-2013, 09:23 AM
Buddy...I don't know what to tell you that sucks ? There should of been a nipple to attach the oil line to the PTO side on top where you already have a hole .
post #38 of 78 (permalink) Old 01-21-2013, 11:02 PM Thread Starter
dhridenh's Avatar
does any one have any ideas on what to do about this oil line for the pto side crank bearing
dhridenh is offline
post #39 of 78 (permalink) Old 02-22-2013, 11:16 PM Thread Starter
dhridenh's Avatar
ok update on the triple i found 1/8 inch copper line for the crank oil bearing hole 2 out of 3 cylinders are running so i went out got a new sett of boyesen reeds new fuel pump new fuel lines and new carb boots i have most of it installed tomorrow after work i am going to try to fit the new fuel pump on then start the pig up hopefully i will have all 3 cylinders running and be able to ride this thing i have never driven a triple and every one says its great well i want to feel this awesome power from it so lets see
dhridenh is offline
post #40 of 78 (permalink) Old 02-22-2013, 11:20 PM
Rick
indyryder500's Avatar
over that 500 they are nasty!, but do NOT get that tank stuck.
97 ultra spx slp can geared clutch and 144 studs.(mine)
96 XLT studded with reverse(12y/o son)
98 xcf 440 (wifes sled)
96 puma 340 elec start(kids sled)
96 cougar 550 2up bone stock (sold)
96 XCR 440 clutched (sold)
92 indy 500 bored,clutched. piped(sold)
85 indy 400 (11 y/o son's sled)(sold)
87 yamaha excel 340 (parting out)(sold)
2011/2012 miles :00000000
indyryder500 is offline
