Please Take time to read and help. 650 Running issues - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-06-2013, 09:19 PM   #21 (permalink)
xflyer53's Avatar
The guy with the y pipe is also selling the can too. You could probably make a deal with him for both.
'92 Indy 650
'95 Indy XLT 600, plastic skis, skid plate, cobra windshield, XTRA 10, full Fox package, 1" riser
xflyer53 is offline   Reply With Quote
Old 01-07-2013, 04:45 PM   #22 (permalink)
Ok guys, tore down the carbs today. Not sure what is what asfar as stating numbers.. The jets that are in the bottom, not your main but the others, read, 05, 05, 04. wtf that mean? Main jets are 270s. where the needle and seat sit the seat is 1.5. I don't see any other numbers.. where should I be looking.. Carbs are 100% tore down and soaking
1990 Indy 500
1991 Indy 500 short track
1992 Indy light 340
Articat Teen is offline   Reply With Quote
Old 01-07-2013, 05:29 PM   #23 (permalink)
meburdick's Avatar
Can you post up a photo of at least where you're getting those 05,05,04 numbers from?
It's interesting that your main jets are larger than stock - clearly someone has changed them out for a reason. Did this typically motor get used in temps below 20 degrees consistently? If so, that may be why they went up a size.
The needle and seat are correct.
Old 01-07-2013, 05:35 PM   #24 (permalink)
It does have triple pipes and was .20 over when I picked it up.. Maybe this is why? I never had it running until I did top end rebuild
These pipes look terrible.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 05:37 PM   #25 (permalink)
It's not how they look, it's how they run that matters
Old 01-07-2013, 05:48 PM   #26 (permalink)
They run terrible, and sound very bad. Both on the sled and if someone is on it.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 05:50 PM   #27 (permalink)
This is where the 05 04 05 come from Meburdick. I believe that's what they say, theres also a square like thing after. Hard to read
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 05:54 PM   #28 (permalink)
meburdick's Avatar
Ok... The mains being one size over would make sense since it's bored AND has aftermarket pipes on it. It sounds like you have two 50 pilots and a 40... I'm guessing they're stamped 050, 050, 040.
Where did the 04 (040) one come from? Which carb?
Old 01-07-2013, 06:28 PM   #29 (permalink)
Pto side, Why would he throw in 50s.. If anything your supposed to go down on pilot jets. They come stock with 45s I believe
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 06:29 PM   #30 (permalink)
meburdick's Avatar
Nope. Stock for that motor is 50.
Old 01-07-2013, 06:34 PM   #31 (permalink)
interesting, should I just throw another 50 in it or should I drop to 40s... What exactly is this doing when dropping it.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 06:43 PM   #32 (permalink)
meburdick's Avatar
When you reduce the jet size, you're reducing the amount of fuel that can be drawn in with the same amount of air. As such, you're making the mix leaner. While this may improve the feel, running too lean will cause a burn-down.
When you're adjusting jet sizes, you want to use jets that are never too small for ANY of the conditions you will be riding in. For example, if you ride in below-zero weather, you wouldn't want to adjust your jets for 30 degree weather - you'll end up way too lean during the typical conditions and wreck the motor.
Some motors actually came with one pilot jet of a different size, but your motor isn't one of them. I would make them all match, and I would use 50's. You might want to research the manufacturer of those pipes, though, and ask them what the new jet requirements are with those installed.
Old 01-07-2013, 06:46 PM   #33 (permalink)
Ok thanks, I ordered a single exhaust header off ebay so I can run my single pipe, just to have both and see if theres a dramatic difference when Its put together. I got a range of jets from 250 - 290 so I will try the 260s with the stock pipe, just to bring It to stock and try it. Like I said the sound of these pipes is absolutely disgusting.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 06:48 PM   #34 (permalink)
meburdick's Avatar
What's your elevation where you ride? And, what is the typical temp when you ride? The highest elevation you ever hit? The coldest temps you ever hit?
Old 01-07-2013, 06:50 PM   #35 (permalink)
Right now our season has been crazy! Last week it was -17c, today was -4c. Friday there calling for rain +5c! Right now we have about 3ft of snow.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 07:08 PM   #36 (permalink)
meburdick's Avatar
Do you ride in -17c weather? What matters are the conditions you ride in as opposed to what they might be on days you don't ride.
Old 01-07-2013, 07:10 PM   #37 (permalink)
meburdick's Avatar
-18c to -7c, for elevations up to 900 meters would justify the 270 mains with a stock pipe.
Old 01-07-2013, 07:38 PM   #38 (permalink)
A normal winter would be -24c to -7c or so.
1990 Indy 500
1992 Indy light 340
Old 01-07-2013, 07:39 PM   #39 (permalink)
meburdick's Avatar
I would keep the 270s in there, then. Especially going back to a stock exhaust. If you run smaller jets, you run the risk of leaning it out and burning the motor down.
