1997 polaris Indy trail touring stalling out
I just bought is sled and am a first time owner. It starts with a pull after just two pulls and the electric start works great. I notice the plug wires are really loose on the plugs. They are NGk br8es plugs and the wires are Ngk.
The sled runs good but when I stop it will conk out. It does start right back up most times right away, other times it takes a few pulls or key turns.
Could this be that the wires are loose or more likely something in the carb that needs adjustment.
Thank you
