Indy 650 Clutch Identification - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 01-04-2013, 10:29 PM Thread Starter
jdpol650's Avatar
Hello,
I have a 1991 Polaris Indy 650, Model # 0910758, serial # 1840650 Mfg Date #0061990. The guy I got the sled from had ideas of turning it into a drag sled and to me the clutch has never worked right. I believe the primary was switched at some point and is not the correct for the sled. I have tried the recommended belt and it as to much slack in it. The clutch engages at about 4500 rpm with Polaris Belt #3211042. Riding today in very light fluffy snow I had to be easy on the throttle in order to engage the belt, could not go from half throttle to wide open as engine rpm would get to 5,000 and stop increasing, about 20-30 mph on the speedo. In the picture for the Polaris part book I labeled the parts with what numbers I have on my clutch. Sliding sheeve 480 092889. Any help on identifying the clutch and any other suggestions are appreciated.
jdpol650 is offline
post #2 of 9 (permalink) Old 01-05-2013, 01:47 AM
A pic of said clutch would help too.
post #3 of 9 (permalink) Old 01-07-2013, 03:43 PM Thread Starter
jdpol650's Avatar
Pics
Riding this weekend the clutch did better at engaging every time when accelerating. The clutch does say Polaris on the side, I just don't believe it is for the 650. It also seems that a fuel supply issues has surfaced when trying to accelerate after a wide open throttle run when letting off for the corner the rpm drops as expected but when trying to accelerate from the 4000 to 5000 rpm range the engine rpm won't climb and then the engine dies. The spark was checked and it was all good that's why I think it is the furl pump or fuel pickup as this doesn't happen when the tank is very close to full.
ID:	20157   Click image for larger version
ID:	20158   Click image for larger version
ID:	20159   Click image for larger version
ID:	20160   Click image for larger version
jdpol650 is offline
post #4 of 9 (permalink) Old 01-07-2013, 03:45 PM Thread Starter
jdpol650's Avatar
Pics 2
A few more pics of the clutch
ID:	20162   Click image for larger version
jdpol650 is offline
post #5 of 9 (permalink) Old 01-07-2013, 05:02 PM
The clutch itself looks real and genuine to the sled, But its hard to tell. All indy primarys are interchangeable. What matters is the weights and spring set up you are running. Check buttons on the spider. Also see how much play you have side to side with the weights. Mine let go this weekend with the same symptoms. My weights had no bushings left.
1990 Indy 500
1991 Indy 500 short track
1992 Indy light 340
Articat Teen is offline
post #6 of 9 (permalink) Old 01-07-2013, 05:27 PM
Quoted: 102 Post(s)
All Polaris clutches used on Indys are not interchangable. Some of the clutches on the twins look identical at first glance but use a different offset. Use of the wrong clutch can wipe out the PTO side crankshaft seal. To be safe, a good rule is any clutch used on a Fuji triple will work on the other Fuji triples.
I agree with all the rest that Aritcat Teen said. It's very possible a good cleaning will bring back your performance. When cleaning, look for the stuff he suggests; worn bushings in the weights, worn main bushing, worn spider. To fix the weights is easy, the other issues will require purchase of specialty tools to disassemble the clutch and a bit of work.
BC_Dan is offline
post #7 of 9 (permalink) Old 01-07-2013, 07:11 PM
From what I see you do not have a blue spring in the primary. I know on my 92 650 I have a blue spring in the primary. The spring and weights maybe changed which would correct your problem.
bigcountrysg is offline
post #8 of 9 (permalink) Old 01-07-2013, 07:34 PM
My 650 had a gold/ yellow in it with 10g weights.. I put in a blue spring from my 440. Big difference. Not sure what they came with stock
1990 Indy 500
1992 Indy light 340
post #9 of 9 (permalink) Old 01-08-2013, 12:10 AM
Quoted: 7 Post(s)
Here's information for the 1991 Indy 650:
Spring Weights (grams)
Production Gold 10 A/L (53)
5000-8000' Blue 10M Blue (47.5)
8000-12000' Blue 10M White (46)
Last edited by steepndeep; 01-08-2013 at 12:15 AM. Reason: trying to get columns to line up better
steepndeep is offline
