1996 500 "pulsing"
my carberated 500 started pulsing real bad yesterday,
by pulsing i mean: it barely starts, then you have to pump the throttle to keep it going, after a few seconds of that it will take off as if normal for 2-3 seconds then die out and you need to start over,
all the while the HEADLIGHT PULSES IN AND OUT, not fully in unisen with the engine rpm,
is my most likely solution a new voltage regulator?
