96 XLT 600 Coolant Check Valve Flow Direction? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-31-2012, 03:49 PM   #1 (permalink)
phazed
Just picked up a 96 xlt 600 that came with an overheating problem.
Trying to troubleshoot/replace everything that could be causing it.
In regards to the check valve that is connected to the coolant overflow, which direction is it supposed to allow coolant to flow? To the engine or to the overflow? Just trying to make sure mine is installed correctly. It appears to function right (I can blow air back into the engine, but if I pull the hose off the engine I cannot blow air into the overflow). But just making sure.
Thanks
cloead is offline   Reply With Quote
Old 12-31-2012, 05:26 PM   #2 (permalink)
should flow twords the engine
wildman04252 is offline   Reply With Quote
Old 01-02-2013, 10:34 AM   #3 (permalink)
phazed
Thanks!
