700 VES max RPM? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-31-2012, 08:11 AM   #1 (permalink)
700 VES max RPM?
What should my 2004 700 VES (Edge Classic) engine turn at top RPM? I am getting about 8000RPM. is that about right?
/Jimboat
2004 700 Edge Touring
Jimboat is offline   Reply With Quote
Old 12-31-2012, 01:53 PM   #2 (permalink)
guitarman69's Avatar
8200 should be your max,
Ride, Wreck and Repair
guitarman69 is offline   Reply With Quote
Old 12-31-2012, 02:40 PM   #3 (permalink)
thanks, guitarman69. it sounds like we're in the right range. do you know if the engine has a limiter to 8200 RPM or does it just self-govern to a max of 8200? (ie - what happens at 8200? Do i need to be sure to keep RPM below the max? or will the engine keep be in safe RPM?)
thanks for your advice!
/Jimboat
Old 12-31-2012, 05:57 PM   #4 (permalink)
The flyweights set the maximum RPM of the engine. You use the weights needed to achieve the RPM required. The max RPM is near the peak torque value for the engine and usually just past the peak HP. If you were to go to 8300, there won't be any damage to the engine, but HP will be off significantly. 2-stroke engine HP and torque drop like a rock once the max. numbers are reached, there's no advantage to increasing RPM past the maximums.
Greatly increasing RPM, such as to 9000, will prematurely wear the engine and can cause engine damage. Unless other modifications to the engine are done to move the peak HP and torque, stick with the factory numbers.
Old 01-01-2013, 08:31 AM   #5 (permalink)
thanks BC_Dan.
/Jimboat
Old 01-01-2013, 09:33 AM   #6 (permalink)
Need Snow!!!!!
Brummo's Avatar
I'm always worried about running max RPM's. Should I be? It's the "red line" that scares me, I mean, red is bad...
http://www.iowa-snowdrifters.org/
'10 Polaris Rush 600
2700 miles, Studboy Deuce Carbides
'04 700 Classic 6700 miles
M-10 suspension, Boyesen Reeds
Stud Boy Deuce Carbides
Brummo is offline   Reply With Quote
Old 01-01-2013, 09:40 AM   #7 (permalink)
i have the same worries, Brummo. that was the exact reason for my question. i wanted to know if i had to watch my tach closely when i am in that "redline" region, or whether the engine would simply prevent itself from over-reving!
i wondered what i would "notice" or "feel" wrt performance if i got to or 'past' the 'redline'?
/Jimboat
Old 01-01-2013, 10:41 AM   #8 (permalink)
Need Snow!!!!!
Brummo's Avatar
I mean we have DET built in to help prevent the motor from things happening to it but things can still go wrong at 8200 RPM.
Old 01-01-2013, 11:09 AM   #9 (permalink)
When you are at WOT, the theory is to set up the primary to give you near max. torque and HP. The primary will allow the engine to spin to that RPM and then stay there as the secondary senses the torque and shifts to higher gear ratios. Certainly, there will be more wear at WOT than at medium RPM, but the engine doesn't come apart like a 4-stroke. There's no danger in it coming apart if it hits the theoretical "red line" every time you run it. Mountain riders do that often, it's how you keep the sled going forward on the steep stuff and in the powder. And there really aren't many moving parts in a 2-stroke, there's no valve train and valves to get sucked in. It's easy to turn 10k, but not useful if the power drops off at 8k. You usually aren't at the max. RPM for very long, on the flats you will be going way too fast if you pin it and hold it and in the mountains, you run out of hill eventually and have to stop at the top or turn out (or get stuck!! )
Old 01-01-2013, 12:00 PM   #10 (permalink)
Need Snow!!!!!
Brummo's Avatar
I understand that. Makes sense, but freaks me out.. LOL
Old 01-01-2013, 03:24 PM   #11 (permalink)
thanks for your great explanations, Dan!
So, if i were to just "pin" the throttle and let the engine go all the way up to as much RPM as it wanted to go to (gives me the willies just thinking about it!), then what sensation or what response would my engine give me as it gets to max RPM? or above?
/Jimboat
Old 01-01-2013, 04:26 PM   #12 (permalink)
The weights set the max running RPM. Once that RPM is reached, RPM doesn't go higher. If you were to pin it with no-load, RPM may climb higher, that would not be wise. So if you pin it under load, the clutches shift out until there's no more HP to drive the sled faster. RPM remains the same with speed being variable; if you were to hit some deep powder or a steep spot, the RPM stays the same but the secondary senses greater torque on the track so the clutches shift to a lower ratio. On a long pull on smooth snow or ice, the RPM may climb a bit over the intended RPM, but not by much.
Most 2-strokes have a very narrow power band, with some sleds only having max. HP/torque for about 200 RPM so it's important to keep the RPM in the powerband. Some of the newer engines have a much greater powerband and will pull harder for longer but are still limited by the clutching.
Old 01-01-2013, 05:15 PM   #13 (permalink)
When both units are balanced properly, the engine will never exceed peak rpm by more that 200 and will always drop back and maintain the desired peak.
The preload of the spring and the angle of the helix in the secondary will determine how fast it achieves that peak and how well it holds with out backshifting under load.
Old 01-02-2013, 08:19 PM   #14 (permalink)
So other than the speed, I should not be too worried about WOT once in a while.
04 700 Classic w/ M-10
90 Indy 500, 11,XXX mi
rbrumm is offline   Reply With Quote
Old 01-03-2013, 12:54 AM   #15 (permalink)
joshkidner's Avatar
exactly. i mean i still wouldnt suggest WOT even on straight shots for long periods without letting it rest a little, but holding it down for some seconds for that rush of speed or to get up a hill wont hurt.
