1998 Polaris Indy 500 pilot jet fully closed - Help! - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-30-2012, 10:08 PM   #1 (permalink)
Hi, I just bought this sled and went to clean the carbs. I disassembled and tried to turn the pilot air jet in to determine the number of turns and found that it was already all the way in (fully closed)! I checked the second carb and that jet was also fully closed. This is the first time I have seen a carb with the pilot air jet fully closed. Could this be correct? If not should I assume the previous owner miss set them? What would a good default setting be or is there a procedure on setting a messed up pilot jet?
Its a 1998 Polaris Indy 500 (Fuji) with Mikuni Round slide Carburetors.
Thanks in advance for the help!
amedman is offline   Reply With Quote
Old 12-30-2012, 10:27 PM   #2 (permalink)
Rczr600rider's Avatar
It's likely the carb was so badly in need of cleaning that it caused a lean condition and the previous owner turned them in to compensate, rather than fixing the problem. Do a thorough cleaning and try them out. If it's still too lean you could go up a size on the pilot jets.
Old 12-30-2012, 11:53 PM   #3 (permalink)
Once you have the carbs thoroughly clean, turn the air screws out one full turn from lightly seated.
Old 12-31-2012, 12:33 AM   #4 (permalink)
Thanks! The carbs were VERY dirty so that may explain it. For the life of me why wouldn't he just clean them!
Old 12-31-2012, 07:24 AM   #5 (permalink)
Ultrafrozen's Avatar
From page 5.15l of the service manual, 0.75 turns on the air screw.
Gallery Pictures.
Current Sleds: A few
