I think too much gas not sure - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-29-2012, 08:25 PM   #1 (permalink)
So i was able to get my 98 xlt out today and the throttle is acting crazy a little sluggish getting going the acts ok until some were between half and thee quarter throttle. If i go fill throttle it just bogs like crazy and smokes i have a new fuel pump thinking maybe not enough gas I'm lost
f16dcc431 is offline   Reply With Quote
Old 12-29-2012, 08:28 PM   #2 (permalink)
Clean your Carbs
Old 12-29-2012, 08:42 PM   #3 (permalink)
I cleaned them 2 months ago but i will do it again i hope that fixes it
Old 12-29-2012, 08:51 PM   #4 (permalink)
from what you describe it sounds like a carb issue. I have seeen carbs that were cleaned a month ago have issues. The gas is just crappy.
Old 12-29-2012, 08:54 PM   #5 (permalink)
Mighty Quinn's Avatar
How bought a fouled spark plug ? On a triple feel each cyl. & exhaust after it starts to get warm ,a cold cyl. & ex. will point out a foulded plug?This may help.
Old 12-29-2012, 08:57 PM   #6 (permalink)
One problem I had on my 650 was the red kill switch on the handle bar. It was shorted out I by passed it and the problem was gone. Of course this is a safety issue but a safety tether from the motorsports store was cheaper then a new kill switch.
Old 01-01-2013, 06:35 PM   #7 (permalink)
I cleaned the carbs and it made a huge difference. but now its kinda doggy getting up to 5000 rpms after that she rips and about every 40 miles i got to swap around the plugs because it will start dogging out all around so i will look at the plugs and put the dirtiest one in the cleanest one and then she runs crazy again after 5000 rpms.
Old 01-01-2013, 06:41 PM   #8 (permalink)
Sounds like either you have your carbs not adjusted properly. Or you may have a bad needle.
Old 01-01-2013, 08:15 PM   #9 (permalink)
Do you know the stock setting for the air screw
Old 01-01-2013, 10:03 PM   #10 (permalink)
XLT Spartan's Avatar
One full turn out from lightly seated on your air screw.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
XLT Spartan is offline   Reply With Quote
Old 01-01-2013, 10:41 PM   #11 (permalink)
Great i will try that tommorow and see were it gets me and we can go from there ill let you know how it turns out
