Do all cylinders fire at the same time on an 95 rxl 650? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-29-2012, 12:10 PM   #1 (permalink)
Wondering if they fire at the same time, i traced my bogging problem back to efi box not sending power to the flywheel side injector. Injector tested good and has proper power, but its not getting the ground signal from the box. Could that be a relay? Or if they all fire together, can i tap into the ground signal from one of the other injectors?
Sent from my DROID4 using Snowmobile.com App
ben.simons is offline   Reply With Quote
Old 12-29-2012, 12:47 PM   #2 (permalink)
joshkidner's Avatar
idk bout rxls but im pretty sure xlts send spark at the same time, not sure how the piston postions are at any time but if sparks your problem switch te caps
Old 12-29-2012, 01:29 PM   #3 (permalink)
Just not firing in the right cylinder. It was showing a code:21.. which is flywheel side injector, but the injector itself tested good, and the ground coming from the efi box for that injector wouldnt read on the multimeter like the other 2 did
Old 12-29-2012, 07:52 PM   #4 (permalink)
Convert it to Carbs and you will be a lot more happy.
Old 12-30-2012, 05:32 AM   #5 (permalink)
Is the wires to that injector reading good, could just be a bad connection.
Old 12-30-2012, 09:15 PM   #6 (permalink)
Nothing coming from the wire to the injector. Tested the other 2 and were fine, so its coming from the ecu..
Old 01-06-2013, 12:07 PM   #7 (permalink)
I replaced the ecu box.. put the new one in today and now its reading an error code for all 3 injectors! Any advice?
