12-27-2012, 03:48 PM
#21 (permalink)
It has a fitting unless someone f'd it up
12-27-2012, 03:53 PM
#22 (permalink)
Originally Posted by Polaris650freak
Haha right. I just didnt know if the older models had the fitting, pretty sure they do.
12-27-2012, 04:10 PM
#23 (permalink)
Since 1973 I know for a fact that they've had it. Haven't owned anything older that that though
12-27-2012, 04:15 PM
#24 (permalink)
Well cool should be easy then!
12-27-2012, 04:22 PM
#25 (permalink)
Originally Posted by Funfettie
I dont believe there is a fitting that can be unscrewed from the tank.. I thinks its once large molded piece of plastic, but ill double check when im home again this weekend. If it is, that would be easy, but from what i remember, im going to have to go through the fill hole in the top. Im thinking a very long pair of needle nose pliers will be needed..
Polaris parts fiche doesn't go back to '84. But, for '85, it shows it as an individual piece. I think you'll be good.
12-27-2012, 04:26 PM
#26 (permalink)
awesome, should be a breeze! thanks guys!
12-27-2012, 04:35 PM
#27 (permalink)
That's why you need the old micro fiche projector with all the slides!! I have very early 70's through early 2000's
12-27-2012, 04:51 PM
#28 (permalink)
The problem is, you pull those slides out at the holidays and show them like vacation photos...
12-27-2012, 05:07 PM
#29 (permalink)
Lol there better than vacation pictures
12-27-2012, 07:36 PM
#30 (permalink)
it is probably a fitting it was on my 88 trail and i fished the old line out with a piece of oxyacetylene welding wire bent to a hook shape about the size of the line it worked good
12-27-2012, 08:28 PM
#31 (permalink)
Thats a very good idea, using a piece of wire to ark the hose to the bottom of the tank. Thanks for the tip!
