94 polaris RXL 650 track wont turn when sitting on ground. only when lifted up. help! - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-20-2012, 06:30 PM   #1 (permalink)
I have a 94 polaris RXL 650 triple.. just got it. Only 1200 miles on it.. It will start, but then if i give it any throttle it sounds boggy and the track wont turn at all, but if i block up the rear end, the track seems to turn fine... any body have any idea of what it could be? Clutch maybe? Im new to snowmobiles, but know motors fairly well.. and it ran perfect when it was stored for the summer.
Sent from my DROID4 using Snowmobile.com App
ben.simons is offline   Reply With Quote
Old 12-20-2012, 06:42 PM   #2 (permalink)
scrammy650's Avatar
secondary clutch might be an issue welcome to the forum
scrammy650 is offline   Reply With Quote
Old 12-20-2012, 08:59 PM   #3 (permalink)
Should i take it apart and clean it? Or can it be adjusted?
Old 12-20-2012, 09:01 PM   #4 (permalink)
And dumb question... but is the secondary the one in front or the one closer to the rider?
Old 12-20-2012, 11:36 PM   #5 (permalink)
Secondary is the one closest to rider and I would take it apart and clean. Pay attention to which hole the spring is in on the helix.
Old 12-21-2012, 02:52 AM   #6 (permalink)
scrammy650's Avatar
also make shure u got battery fully charged and it holds
Old 12-21-2012, 07:22 AM   #7 (permalink)
Just put a brand new battery in, but im gonna try cleaning the clutch and see what happens. Thanks
Old 12-27-2012, 11:31 AM   #8 (permalink)
So im pulling the secondary clutch today, is it just that center bolt to remove it? And you guys have any info for this dummy on what steps to take to take it apart?
Old 12-27-2012, 11:45 AM   #9 (permalink)
gbousum's Avatar
yes, its only one center bolt holding it on, then it should slide right off the jackshaft. Cleaning them is pretty basic, once you have it off, remove the outside bolts and everything should come apart, use a parts diagram if you need to help you along the way. Remember where the spring is set (if it has different settings for the spring) and inspect everything while you have it apart, check for any excessive wear.
here is the part diagram for that clutch:
OEM Polaris Parts, Polaris ATV Snowmobile Parts
gbousum is offline   Reply With Quote
Old 12-27-2012, 11:49 AM   #10 (permalink)
Thanks a bunch!
Old 12-27-2012, 12:05 PM   #11 (permalink)
joshkidner's Avatar
Clean the primary clutch and make sure the belt doesnt have any worn/burnt spots. Also make sure the key that goes between the secondary and the jackshaft isnt broken. Its just a square piece about 4 in long. With that broken it could still spin off the ground but not have enough torque to when its on the ground
Old 12-27-2012, 03:26 PM   #12 (permalink)
I got the secondary off and am taking it apart right now to clean and go through it, is it gonna come flying apart when i take it apart because of the spring inside?
Old 12-27-2012, 03:38 PM   #13 (permalink)
joshkidner's Avatar
Out of curiosity, is the shaft key all in tact (or missing)? The jackshaft is keyed along with the clutch. Without the key and with some muscle you can spin the clutch around the jackshaft. Double check that first before you take the clutch apart. My brother messed with my sled and lost the key and it did what you are explaining.
Old 12-27-2012, 03:43 PM   #14 (permalink)
Theres nothing there! Omg! All thats there is dirt!
Old 12-27-2012, 03:47 PM   #15 (permalink)
joshkidner's Avatar
Haha the key is prob. A $3.00 part. I had a feeling this was your issue. Line up the keyed part of the clutch to the keyed part of the shaft and when you get a key slide it in. It might need a light hammering to get in. Look on ebay or amazon or go to your local hardware store. Find the size key it takes. Good luck!
Old 12-27-2012, 03:56 PM   #16 (permalink)
Ok now i feel stupid! Ran outside to see if it fell inside the engine compartment, and i found it on the ground! So it must have been in there cause i just took the secondary off.... so now what?... could it be worn out?
Old 12-27-2012, 03:59 PM   #17 (permalink)
joshkidner's Avatar
Well it could of fell out inside the sled before you took it apart. If the clutch seems good as is try putting it back together. There quite easy to put on and take off after the first time. How long is it? Ive had one that broke in half on a go kart and wasnt long enough.
Old 12-27-2012, 04:06 PM   #18 (permalink)
Its about an inch and a half
Old 12-27-2012, 04:07 PM   #19 (permalink)
I put the clutch back together and im goin out to try to put the pin in and see if it helps
Old 12-27-2012, 04:15 PM   #20 (permalink)
joshkidner's Avatar
Seems a little short. How you can tell is put it on the ground with the hood up, rev it and does the secondary spin?
