12-27-2012, 04:41 PM
#21 (permalink)
I just put it back on and when the track is off the ground the track moves good, but when the track is on the ground it spins but doesnt open up
Sent from my DROID4 using Snowmobile.com App
12-27-2012, 05:22 PM
#22 (permalink)
Secondary spinning/track not moving stil sounds like the key. Inch and half is pretty short it might not be all the way in? When the secondary is moving, is the jackshaft moving? If it is it might be something with the chaincase or something. If its not its gotta be the key
12-27-2012, 05:52 PM
#23 (permalink)
Is it just a chain and sprocket in the chain case?
12-27-2012, 05:55 PM
#24 (permalink)
Basically. And a tensioner. Make sure if you take the cover off you have new chaincase oil to put in it.
12-27-2012, 09:41 PM
#25 (permalink)
What usually goes wrong in the chain case?
12-27-2012, 10:05 PM
#26 (permalink)
Chain stretches over time
93 mach1 670
02 rmk 800 162
95 powder special 580
12-27-2012, 10:30 PM
#27 (permalink)
Do what i said to do above. This will help us figure out where the problem is. If its in the clutch or further on.
12-28-2012, 07:05 AM
#28 (permalink)
Ok, gonna work on it today, and i thought id throw out there that when i pulled the chain case dip stick, theres was metal shavings magnetically stuck to it
12-28-2012, 07:41 AM
#29 (permalink)
That isnt nessecarily bad. You need to change the chaincase oil. I got 12oz bottle of it for $7 and it didnt even take quarter bottle.
12-28-2012, 05:54 PM
#30 (permalink)
Put fresh chain case oil in the day i found out it wouldnt move...
12-28-2012, 09:38 PM
#31 (permalink)
Update-------
Ok guys here's an update of my sled issue... i had a sled-head come over with all his testing equipment and knowledge, and what we found was the efi-box isn't putting out a signal to the flywheel side injector.. went through everything.. used jumper wires from battery to efi box harness to injector. Pulled the air box and just gave that one cylinder carb spray and ran like a champ... tested the power output for that injector at the efi box and there was nothing.. so we took it off, brought it inside to take a peek inside... and found a surprise! Its been fixed before.. somewhere along the lines of the sleds life someone had the box either reconditioned or fixed by someone who knows circuit boards with aftermarket capacitors from radio shack! So just thought id share the findings for anyone else who has this problem and needs help... and thanks guys for all your helpful input on this issue.
01-01-2013, 11:24 PM
#32 (permalink)
No problem. Whats important is you found your problem. Have you got it running good yet? Im curious to know!
01-06-2013, 11:02 AM
#33 (permalink)
Ok i got a new ecu and now its showing error codes for all 3 injectors! Any advice?
01-06-2013, 09:30 PM
#34 (permalink)
Make sure all your wire connections are good. Try running three quarters of a bottle of sea foam in your tank to clean the injectors out.
-my ride
01-17-2013, 09:48 AM
#35 (permalink)
did you get the track to move? I have the same problem with my 95 RXL.
