1991 indy 650 loss of power - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-23-2012, 11:58 AM   #21 (permalink)
meburdick's Avatar
Offset and deflection should be checked with a new belt for best results. Take it out and drive it, warm up the belt, then pull it into the garage. You're looking for there to be about 1" - 1.5" of "play" in the belt at the middle between the primary and secondary. The upper edge of the belt should be sitting just slightly out of the secondary (think: the thickness of a dime).
For the chain, that's simple... Loosen the jamb nut on the tensioner and screw the bolt all the way in by hand. Give it a good, solid twist to make it as tight as you can using only your hand. You're not looking to really torque it here, just get it tight. Then, back the tensioner off 1/4 turn, hold it in place, and tighten the jamb nut.
Old 12-24-2012, 10:43 AM   #22 (permalink)
thank you meburdick i haven't actually tested them but from the messing with the belt it does seem like its got about that much play. also from memory im pretty sure the belt does sit about a dimes thickness out of the secondary.
what do you think could be causing the lose of top end rpm's?
polaris_indy22 is online now   Reply With Quote
Old 12-24-2012, 10:53 AM   #23 (permalink)
meburdick's Avatar
Track too tight, worn / seized bearings in the idler wheels, worn our bad bearings in the jackshaft or driveshaft, chain too tight or worn, restriction in the exhaust, worn primary clutch buttons or spring, pitting on the clutch sheaves....
Basically, you have look for things that will impede getting all of the power to the snow. Look at things that can constrain the motor, bind the track, our anything else that would prevent the motor from getting up to full speed.
Old 12-24-2012, 11:01 AM   #24 (permalink)
thanks meburdick u have been alot of help. i was really hoping to have the sled 100% this season but looks like its going to take another summer of work. im a little low on money right now. i will check all those things sometime over my christams break if i get a chance. ik im going to need a new track soon. which is going to suck those things arnt cheap
Old 12-24-2012, 11:58 AM   #25 (permalink)
meburdick's Avatar
At a minimum, put the skid up in the air, remove the belt, and check out the general "easiness" of rolling the track by hand. Check the tension there and on the chain in the chaincase. These are all zero-cost steps.
Old 12-24-2012, 12:26 PM   #26 (permalink)
alright ill do that today. i think im going to take it with me when i go to see my dad because he know what hes doing with motors better than i do. im still learning. plus my tool supply is really limited. hes got about any tool u can think of. im also going to check the crank seals with some carb cleaner
Old 12-24-2012, 01:52 PM   #27 (permalink)
possible new reeds
CRCINDY400 is offline   Reply With Quote
Old 12-24-2012, 02:04 PM   #28 (permalink)
meburdick's Avatar
Originally Posted by CRCINDY400 View Post
possible new reeds
No reeds in this motor.
