fuel line - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 12-19-2012, 10:06 PM Thread Starter
Custom580's Avatar
fuel line
i have a 92 polaris 650 fuel like is broken. on the carb closest to the clutch the fuel line on the bottom of the bowl craked and broke so it was leaking gas everywhere. where does that fuel line go to.
Sent from my SGH-T959V using Snowmobile.com App
Custom580 is offline
post #2 of 10 (permalink) Old 12-19-2012, 10:17 PM
Snowweasel's Avatar
It doesnt go anywhere. That line that comes out of the bowl is just to collect sediments. Clip the line and put a screw in it to plug it up.
Snowweasel is offline
post #3 of 10 (permalink) Old 12-19-2012, 10:43 PM
Quoted: 102 Post(s)
It comes with a plastic plug, if yours broke off, it's likely in the engine bay somewhere.
BC_Dan is offline
post #4 of 10 (permalink) Old 12-20-2012, 02:28 PM
Waiting for snow in PA
re
It's nice to have a good length of say 6" or more of hose on the bottom of your carb, with the special plug it came with. Not only is it a sediment trap but it's more importantly a water trap. Water sinks so it winds up in the hose with sediments- much better than sitting in your carb causing corrosion and freezing up. The plug it there so you can remove it and drain the line every year. If your hoses are of that age it would probably be a good idea to put new hoses on the entire system along with a new fuel filter. It's all 1/4" line, just change it out one line at a time, easy to do.
Thanks! TJ
2012-13--- 264 miles @ Laurel Highlands PA
1996 Polaris XLT with Xtra12
1996 Polaris Indy Lite GT
94sportwithkids is offline
post #5 of 10 (permalink) Old 12-20-2012, 06:28 PM
Between lost and found!
gpa21's Avatar
What he^ said. i did it with my xlt sp 580 and it really isnt hard, but removing the air box might give easier access too!
JUST SAYIN'
gpa21 is offline
post #6 of 10 (permalink) Old 12-20-2012, 09:01 PM
Snowweasel's Avatar
This would be difficult to do, but on a friend of mines sled (1993 xlt mod sled), he put a 4 point connecter on the bottom lines from all 3 carbs. And on the end was a petcock attached to a drain going out the bottom of the sled. After every ride he would shut off the petcock near the tank, then reach under and drain the lines from the bottoms of the carbs with the secondary petcock. Therefore he never had gas in his carbs causing corrosion and any sediments never got the chance to accumulate. I have been wanting to set something like that up on my sleds ever since
Sent from my iPod touch using Snowmobiles
post #7 of 10 (permalink) Old 12-20-2012, 11:05 PM Thread Starter
Custom580's Avatar
another thing is i dont have any lights or rpm gauge. what would cause that
post #8 of 10 (permalink) Old 12-21-2012, 03:20 AM
mikemalibu's Avatar
Quoted: 15 Post(s)
If u have tail lights but nothing on the pod I would check the connection under the pod for corrosion or loose or broken connection or wires. Then follow the harness all the way back to the engine and check that connection for the same thing. Also check your ground wire and the connection of the voltage regulator. It is located above your right foot hold. And of course check for blown out bulbs which could indicate a bad voltage regulator. Wireing probs are sometimes a bear to Chase down. Sometimes the old jiggle test finds the prob. Grab on section of wire at a time with it running and shake it pull it push it till something changes. Good luck!
94 indy storm - my hot rod
03 yamaha venture - hers
82 panther - my collector
95 xlt 600- kids sled
mikemalibu is offline
post #9 of 10 (permalink) Old 12-21-2012, 03:22 AM Thread Starter
Custom580's Avatar
i dont have tail lights
post #10 of 10 (permalink) Old 12-21-2012, 10:27 AM
Quoted: 102 Post(s)
It's likely the lighting coil in the stator or a voltage regulator blew all the bulbs. I would suspect the lighting coil.
BC_Dan is offline
