Temp light - 02 XC 600 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-09-2012, 12:33 AM   #1 (permalink)
XLT Spartan's Avatar
After running today i notice the temp light was coming on when i rev the sled. I'm confuse on why the light would be coming on only when I hit the throttle, and not at idle? Sled is running on a stand in about 40 - 45 degrees and running for 5 to 10 minutes.
Here is everything that's been checked:
- checked thermostat (working)
- water pump - have coolant flowing into the coolant bottle in a steady stream from the head until the thermostat opens.
- Bled the system cooling system.
- Both heat exchangers are warm/hot.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
XLT Spartan is offline   Reply With Quote
Old 12-09-2012, 12:50 AM   #2 (permalink)
Live to ride
99Polaris500's Avatar
I remember hearing that the temp sensor goes bad on those sleds, causing the light to come on. If everything else checks out good, that could be the problem.
'99 Polaris xc 500
'91 Arctic Cat prowler 440
99Polaris500 is offline   Reply With Quote
Old 12-09-2012, 09:38 AM   #3 (permalink)
Originally Posted by meburdick View Post
If, when the temp light comes on, the heat exchangers are "hot" (not just warm), then you're definitely overheating the motor.
The air temp is well above what that motor is jetted and adjusted for, so it will run less than optimal. If you're also overheating the motor, you're exacerbating the issue.
Shouldn't the light stay on if it was overheating? Not just when I'm on the gas?
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
Old 12-09-2012, 11:40 AM   #4 (permalink)
Live to ride
The temp sensor is probably bad, that's why it only comes on when you rev it up. If it was overheating it would stay on like you said. When you rev it up, your giving it more power, kinda like how your headlight gets brighter when you rev it.
'99 Polaris xc 500
Old 12-09-2012, 02:23 PM   #5 (permalink)
I drained the fuel because I read this could be a DET indicator, but no change. The heat exchangers are very hot to the touch as well as the hoses. How warm do they typically get on these sleds? Still, light is only coming on after 10 - 15 mins on rev up on a stand.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
Old 12-09-2012, 02:28 PM   #6 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
Might have air bubbles in the system. Know anyone that has an airlift? Is your coolant mixed correctly? If not, it can play with temps
Snow: The other white drug!
Old 12-09-2012, 03:06 PM   #7 (permalink)
I just went to load it into the trailer to bleed the system at more of an angle, an now the temp light is on and staying on. Once she cools I am going to bleed it again.
How would I know if it was the water pump?
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
Old 12-09-2012, 09:14 PM   #8 (permalink)
I let the sled sit for a while, but the temp light is still staying on. So confused and frustrated. Snow is starting to fall.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
Old 12-10-2012, 06:18 AM   #9 (permalink)
JheLrey's Avatar
Put it on the trailer with the front in the air... Take the coolant bottle cap off and let it run. Also, crack the bleed screw by the thermostat housing in case you have air in there.
Old 12-10-2012, 06:18 AM   #10 (permalink)
JheLrey's Avatar
Also, pull the recoil off and check your water pump belt.
Old 12-10-2012, 02:13 PM   #11 (permalink)
Tip the sled at a 45 angle and hold it while running. This puts the coolant bottle at the highest point in the cooling system and helps any air escape if u still have air in the system.
Sent from my Desire HD using Snowmobile.com App
polaristech is offline   Reply With Quote
