secondary clutch adj. 96 xlt rmk triple 600 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-06-2012, 05:50 PM   #1 (permalink)
rookiesledder17's Avatar
Cool secondary clutch adj. 96 xlt rmk triple 600
Hello folks, just wondering what the adjustment on the outside will do if I were to open the sheaves up more or close the small gap, is there a setting to shoot for? Or is it a personal preference? I am talking about the 3 bolts with the washer that rotates to either close the gap or open. What way would lower rpm? Thank you.
secondary clutch adj. 96 xlt rmk triple 600-2012-12-06-15.40.23.jpg   secondary clutch adj. 96 xlt rmk triple 600-2012-12-06-15.41.02.jpg
rookiesledder17 is offline   Reply With Quote
Old 12-06-2012, 11:23 PM   #2 (permalink)
The adjuster is used to compensate for belt wear. As the belt wears, turn the adjuster to move the sheaves a bit closer together. I try to adjust to keep the belt just out of the secondary. Don't rotate the adjuster past the number 1 or it will be difficult to open.
Old 12-07-2012, 05:01 AM   #3 (permalink)
Mighty Quinn's Avatar
Thank you BC Dan your the man ,cuz I was wondering the same dang thing on my 96 Ultra .The manual I have has nothing about that 1 to 5 adjustment?!
