Ethanol plug in strange - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-30-2012, 06:09 PM   #1 (permalink)
mat
Hi me again. I just took my sled out for a bit now that we have enough pow to play in (2008 800 dragon). I am currently running 91 octane 10% ethanol. When I first went out I had a bog in the mid range so I plugged in the pink and black wires. That pretty much cleared up that problem but then when I had it wide open for about 5 seconds it bogged on top end. After that, I again unplugged the ethanol circuit wires and tried again. This time it bogged on the top end after about 1 second of wide open. I can't figure out what is going on here. I would really appreciate any in put.
mat is offline   Reply With Quote
Old 12-01-2012, 04:58 AM   #2 (permalink)
If it's old fuel it's probably begun going bad. Drain it and refill.
Old 12-01-2012, 06:11 PM   #3 (permalink)
mat
there was just a little old gas in the tank before I dumped 20 liters in soo I dont think thats the problem Maybe I should try some additive
Old 12-02-2012, 06:04 AM   #4 (permalink)
You might need t oclean the carbs. Old fuel sits=bad fuel.
Old 12-02-2012, 12:36 PM   #5 (permalink)
mat
It is EFI I guess I'll try running a few tanks of gas through it and see what happens it might eventually clear up :/ Thanks for the suggestions
Old 12-02-2012, 04:18 PM   #6 (permalink)
being an 08 800 have you had all the updates done on it and i would do a compression check just the littlest bit of bad gas will blow them things right up.
Old 12-02-2012, 11:29 PM   #7 (permalink)
mat
I got it from a dealer on consignment and they said the updates were done. I did a test at the start of the winter, and they were 130 psi both sides.
