11-28-2012, 04:50 PM
indy 600 wont run. VERY FRUSTRATING!!!
It starts on fluid. before i put any fluid in it 2 of the carbs had fuel in them (stuck finger inside, rubbed and it was wet/smelled like gas) and i tried spraying fluid in just the one that isnt getting fuel and it wont start. ran fine month ago! starts 1st pull on fluid. help!
11-28-2012, 05:36 PM
How old is the fuel? Have the carbs been cleaned?
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
11-28-2012, 06:24 PM
cleaned carbs out real good last week and it continued. i tested the gas by sphining some out and funneling it into the cyl through the carb by holding the throttle full open.
11-28-2012, 06:28 PM
i think im going to drain all of the gas and clean the carbs pilot jets (only part i missed the first time) and hope i get lucky.
11-28-2012, 06:54 PM
Oh yeah, the pilot jets could be clogged. If you're going to pull the carbs you may want to go through everything again. I typically buy carb cleaner spray and have a can with a basket for carb cleaning... Take all the screws/jets out. Remove any rubber gaskets, then you can throw the entire carb and all the metal parts into the can. Let each sit in the can for a bit while you take apart the next one. Make sure you always have one assembled just in case you forget how they go back together. Take the carb out of the can and hit all the passages with a thin wire to remove any debris. Then shoot the spray cleaner through them. Last, you should blow out everything with compressed air before reassembling.
If you haven't, I would also do a compression check. If you don't have a gauge you can rent one at an O'riley Auto parts store for free. They will also have the carb cleaning can.
If she doesn't start then, at least you can check some boxes on what it's not.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
11-28-2012, 07:06 PM
TRH- Troll Raising Hell
Line in the gas tank could be broke as well
Snow: The other white drug!
11-28-2012, 07:18 PM
i cleaned it pretty well other than the pilot jet. they wernt very dirty either. doubt they got clogged in a month when it wasnt being ran. its getting gas also, i can see the gas going through thelines and smell it in the carbs. i can take them apart and put them back together with ease. either way im going to reclean. anyone else know another cause?
11-28-2012, 07:21 PM
Have you thought about a compression test?
11-28-2012, 07:26 PM
i will do one. i can feel it when i pull it, and it ran like a top last winter. it went over 110mph and thats when i ran out of road!
11-28-2012, 07:29 PM
Compression test, clogged fuel line from pump to carb, bad seat needle, bad fuel pump, clogged pilots.. Lots of possibles.
I've been reading quite a bit lately about cleaning carbs with Lestoil. No need to remove all of the parts, it's bio-friendly, and requires only water to rinse out afterward. The one caution folks seem to make is to remember that certain parts (like gaskets) will swell. Give them a day or two to settle back to normal after you finish rinsing. Otherwise, people swear it works BETTER than carb cleaner.
11-28-2012, 07:34 PM
i dont understand how any of these would work one day and stop the next time i try starting it. like i said its sucking gas. i see a little move through the line with every pull! i know i gotta do all of this to rule out the possibilities but its puzzling!
11-28-2012, 07:36 PM
Change in temps, humidity, more "varnish" developing in the carbs over time... All sorts of things that contribute to the proverbial tipping point that could make it stop working.
Have you checked each of the plugs after a few pulls to see if they're all getting gas?
11-28-2012, 07:44 PM
no... i assumed they wernt or it would start xD. damn sled is going to be the death of me, and my wallet! lol
11-28-2012, 07:45 PM
Make sure everything is setup right on the carbs when you reinstall. Your air screws should be 1 full turn out from lightly seated. Also, make sure your choke plungers are all bottoming out and while you have them out check to see that your choke cables are all pulling when you flip the lever. My 94 started hard, then I figured out one of the 3 cables was shredded.
2 strokes, especially tripples can be a little finicky.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
11-28-2012, 07:49 PM
choke lever is broke. after starting it with fluid 10x it should run without choke. im ordering a new choke lever tomarrow.
11-28-2012, 07:58 PM
Does it start back up when it's warm and you shut it off without starter fluid?
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
11-28-2012, 08:06 PM
i start with starting fluid 5-10 times, each time it runs up to about 10 seconds and dies.
11-28-2012, 08:08 PM
and no it will not start or run without starting fluid. it runs great on the fluid though. i can rev it up and everything until it dies
11-28-2012, 08:23 PM
#19 (permalink)
Shoot! I thought it continued to run. Gotta tell us these things!  Could be the fuel pump. I don't think it would start with fluid if you were flooding and had excess fuel.
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
11-28-2012, 09:03 PM
#20 (permalink)
idk. being its a vaccum fuel pump if it "broke" wouldnt it just be something stuck and i could fix it? im not sure it is broke because i can see fuel going to it.
