Xtra-10 Identification Help Needed... - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-18-2012, 07:05 AM   #1 (permalink)
I purchased a Xtra 10 rear skid and was wondering if there was anyway to identify what it may have come from originally, to help with the purchase of replacement parts. Thanks again for all of your help.
no74falcon is offline   Reply With Quote
Old 11-18-2012, 02:10 PM   #2 (permalink)
Here are some photos...
Xtra-10 Identification Help Needed...-img_0724.jpg   Xtra-10 Identification Help Needed...-img_0725.jpg   Xtra-10 Identification Help Needed...-img_0726.jpg   Xtra-10 Identification Help Needed...-img_0727.jpg   Xtra-10 Identification Help Needed...-img_0728.jpg
Old 11-18-2012, 05:45 PM   #3 (permalink)
joshkidner's Avatar
from what i understand all of the xtra-10's are the same in all the sleds they put them in. the shocks will obviously be 10in travel :P sorry if this doesnt help...
Old 11-18-2012, 10:31 PM   #4 (permalink)
There are at least 3 different Xtra 10s (121", 133 1/2", 136"). Some of the rails have a part number on them that you can go to the Polaris website and start checking numbers. Yours appears to be the short one. It is also my understanding that there are different length front torque arms and mounting locations depending on the year.
Old 11-19-2012, 09:39 AM   #5 (permalink)
joshkidner's Avatar
my bad i assumed he had the 121. all 121" should be the same. just as all 133.5 would all be the same.
Old 11-19-2012, 09:53 AM   #6 (permalink)
smokingcrater's Avatar
In researching my x10 swap, I found there are 2 flavors of the 121. Either referred to as the metric or standard versions, depending obviously on the bolts used. I don't know exactly what else is different, but there are minor differences between them beyond the bolts (different shocks to start with IIRC). (mounting should be the same though)
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 11-19-2012, 11:16 AM   #7 (permalink)
The only other difference would be whether it had oil or gas shocks and if they were re-buildable.
