96 xlt wont start please help - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-16-2012, 09:17 AM   #1 (permalink)
Hey guys I bought an xlt last winter and it always started fine at first but if I shut it down for a while it woul take forever to restart it. It won't start at all now it tries but nothing. I poured a little gas in each cylinder but now it backfires so I'm afraid of it lighting on fire lol. What could be the problem Im terrified that its the problematic PTO bearing.
Thanks guys
Eric
ghostrider_14 is offline   Reply With Quote
Old 11-16-2012, 09:41 AM   #2 (permalink)
XLT Spartan's Avatar
Check to see if your choke plungers are stuck or not bottoming out. Did it run ok when riding it or was it boggy? Also, make sure your throttle cable is properly adjusted and it is returning all the way to the block on the bars. If it's not you are triggering the safety switch. You can pull all day and it won't start. Both are easy to check and at least a starting point. If those are ok it could be your needle seats in your carbs causing it to flood. If I'm not mistaken this was pretty common with the tripps. Shutting off the gas when not running will help. Have you cleaned the carbs lately?
Toys:
93 Vmax 600
94 XLT Special
99 XLT Touring
02 XC Sp 600
XLT Spartan is offline   Reply With Quote
Old 11-17-2012, 02:43 PM   #3 (permalink)
ok got cleaned the carbs and after a ton of pulls she finally fired up but if i shut it off and leave it for a little while it takes forever to get going again what could cause this?
Old 11-17-2012, 02:55 PM   #4 (permalink)
Try shutting off the in line fuel valve before switching off the engine, I'll bet you have needle valve seat wear that needs fixing.
Old 11-17-2012, 03:05 PM   #5 (permalink)
is it a hard job to replace the seat valve? and how do i go about doing it. thanks
Old 11-18-2012, 08:26 AM   #6 (permalink)
Remove carbs, remove bowls, remove floats and needle valve.
Look at the tip, it is most likely metal and will show some wear [it will have curved face rather than straight to tip].
Replace with the rubber tipped ones as they seal better and do not wear so fast.
Old 11-18-2012, 06:52 PM   #7 (permalink)
mine acted like that last season after I rebuilt it,,,,started ok cold and ran well,, shut it off and was a bugger to get going again ,, ,,I got a diaphragm kit to rebuild the fuel pump,,,,seemed to be the fix,,,(it's cheap too)
hosehoundfr86 is offline   Reply With Quote
Old 11-30-2012, 06:08 PM   #8 (permalink)
F.K.A. MOUSE72
ITriumph's Avatar
Sent from my SCH-i705 using Snowmobile.com App
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 11-30-2012, 06:11 PM   #9 (permalink)
F.K.A. MOUSE72
ITriumph's Avatar
Like RJ said. Also under your exaust manifold there are 3- 10mm bolts. One for each cylinder. Take these bolts out and drain the crankcase. Prolly filled up with gas cuz of badneedleseats incarbs
Old 11-30-2012, 07:43 PM   #10 (permalink)
Waiting for snow in PA
There's a lot of "how to" information here:
http://www.snowmobileforum.com/engin...-tos-here.html
Thanks! TJ
1996 Polaris XLT with Xtra12
1996 Polaris Indy Lite GT
93sportwithkids is offline   Reply With Quote
