XC 500 low throttle bog
Have a 2000 XC500. Just bought in spring, today I put a new fuel filter in and started her up to run for a bit. Starts great idles great and seems to get up and go good. I did notice one thing. clutch engaged at around 4000 rpm, if I lightly engaged it so track was barely moving and then punched it, it would seem to bog for a second and then go, it also backfired a few times. This is all with the back jacked up. Gas is fresh, and compression is 120 in both cylinders. It hasn't been run in a year besides this summer when I popped her off a few times. I know it needs to get and go but just wondering if there is something I should check into. Thanks
