slp pipes - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 11-07-2012, 09:58 PM Thread Starter
slp pipes
will twin slp pipes off an 01 600 edge fit on a 04 700 switchback?
vean555 is offline
post #2 of 5 (permalink) Old 11-07-2012, 10:08 PM
joshkidner's Avatar
they likely will fit but likely will not proform as well because they are made to proform best with the motor it was made for. im almost positve it will work and be fine. wait for rjgleasons or bcdans reply. they will tellyou for sure
joshkidner is offline
post #3 of 5 (permalink) Old 11-07-2012, 10:11 PM Thread Starter
alright thank you
vean555 is offline
post #4 of 5 (permalink) Old 11-07-2012, 10:19 PM
joshkidner's Avatar
do they have similar engines? such as xlt's xcr's and indys all did? if so then yeah if not then maybe. im sure if your worred bout fit you could find that on google.
post #5 of 5 (permalink) Old 11-08-2012, 01:18 AM
Quoted: 101 Post(s)
Pipe shape and volume are specific to engine size. The restriction in the pipe is tuned to the engine so that the exhaust pulse from the cylinder hits the restriction and rebounds at the exact time that the fresh fuel/air mix is coming out of the cylinder. The rebound is necessary to shove the fresh gas/air back into the cylinder so that it can be burned.
Using an improperly shaped pipe will not give optimum performance and in some cases, can cause damage to the engine because the rebounding exhaust pulse doesn't return the fresh fuel/air back into the cylinder. That will make the air/fuel mix lean, which can burn hot enough to melt holes in the pistons.
The 01 600 is also a small block engine, the 700 is a big block engine. I'm not sure the manifolds for the small block will even bolt onto the big block.
BC_Dan is offline
